#1 2022-11-23 21:58:24
Localisation on Daedalus previews broken
Just want to make you aware that at least the German localisation in the netinstalls currently is broken.
Got a version dated May 23rd that still is fine. Just got an issue when trying to install with a mirror that the installation of the keyring doesn't progress due to waiting for user input thats not possible in the installer (at least I have no idea how to do that). Will try again without network connection. Trying to load Daedalus to fix this issue: https://dev1galaxy.org/viewtopic.php?id=5364
Also got a version dated Sep 12th and Nov 21st. German Umlauts are not correctly displayed in menus, many menues are broken, and I guess also the German Keyboard layout is not served correctly in the password dialogue. Shot some pictures with my camera if that helps.
#2 2022-12-30 20:52:15
Re: Localisation on Daedalus previews broken
Still the same on the preview dated 2022-12-26.
The May version can be installed fine without mirror (the keyring update via network requires an user input thats not possible), and after first boot apt update does its job ok.
#3 2023-01-05 18:05:04
There is a bug report now with number 733 for this issue.
#4 2023-01-31 03:49:30
ndavilam
Something similar happens to me
But with Spanish on the AMD64 DESKTOP ISO
A lot of text with a common word: _ERR_
