#1 2022-11-10 17:45:18
kaiyel
HOWTO : Fix bind9 managed-keys-zone: Unable to fetch DNSKEY set '.'
I had a need for a local caching-only name server and installed my goto resolver
bind9 on a fresh Chimaera instance.
apt-get install -y bind9 bind9-utils
Out of the box I discovered an error logged to syslog and all lookups failed :
managed-keys-zone: Unable to fetch DNSKEY set '.': timed out
The default location for the "bind.keys" file is "/etc/bind.keys", but the package
locates that file as "/etc/bind/bind.keys".  As such it was necessary to specify the
current file location by editing the "/etc/bind/named.conf.options" config :
vi /etc/bind/named.conf.options
such that :
dnssec-validation auto;
bindkeys-file "/etc/bind/bind.keys";
And, after saving, remove the (likely junked) cache file and journal :
rm /var/cache/bind/managed-keys.bind*
Restart bind and my caching server is now usable.
--K
