#1 2022-10-30 22:31:51
andyp67
chimaera 4.0.0 amd64 netinstall iso is made of cheese
wget -c --limit-rate=11M iso OK
SHA256SUMS OK
Tried two different blank flash drives to write the iso to, and two different blank flash drives to put chimaera on.
Every time;
After partitioning disk, install; RED
DEBIAN/main/libs/libsemanage/libsemanage-common_3.1-1_all.deb was corrupt
console syslog base-installer/debootstrap-failed
Installed chimaera before numerous times fine, was doing a clean install.
Please help, Andy.
#2 2022-11-01 01:01:39
Devarch
Re: chimaera 4.0.0 amd64 netinstall iso is made of cheese
The best way imo is to convert debian netisntall to whatever you need. To chimaera, daedalus, ceres.
It has beautiful GUI installer, firmware image contains wifi drivers and it's never broken.
The best way to prepare boot flash drive is to use ventoy one time only. To add an .iso to ventoy just copy it.
