#1 2022-09-25 08:05:45
driver
package-update-indicator
Just found out about package-update-indicator and read in this thread that gnome-packagekit is required to use the full functionality, which might be true for out-of-the-box funtionality but there is an option in preferences to run a custom command for applying updates.
FluxBB bbcode test
I changed it to /usr/bin/xfce4-terminal which opens the terminal when I click "Install updates". So far so good, but how can I make it open the terminal and run sudo apt upgrade?
#2 2022-09-25 12:08:01
Re: package-update-indicator
/usr/bin/xfce4-terminal -x sudo apt upgrade
#3 2022-09-25 13:22:57
A bit more universal:
x-terminal-emulator -e 'sudo apt upgrade'
The x-terminal-emulator alternative should point to the default emulator, which will be xfce4-terminal in an Xfce system. Using the alternative allows the command to work for all desktops regardless of the specific terminal emulator in use.
#4 2022-09-25 13:23:33
driver
Thank you aitor! Looking forward for updates rolling in.
#5 2022-09-25 13:25:33
driver
Thank you, very helpful!
