#1 2022-09-06 19:19:55
nobodyuknow
name of log for error/warning messages seen during boot
Something is going on during boot, but the messages fly by too fast to read. I looked at a few logs in /var/log, but my eyes are glazing over. What's the name of the log for error/warning messages seen during boot?
#2 2022-09-06 19:26:52
Marjorie
Re: name of log for error/warning messages seen during boot
try /var/log/boot ?
#3 2022-09-06 19:55:03
nobodyuknow
/var/log/boot was the first one I tried, but it does not contain the error messages that fly by. My eyes never were good, but I swear the messages have something to do with BIOS.
#4 2022-09-06 23:22:24
Hi, These can be revealing sometimes... You may need to be root to access these files.
search dmesg for errors,
dmesg | grep -i "erro\|fail\|warn"
search xorg for errors,
cat /var/log/Xorg.0.log | grep "(WW)\|(EE)\|(??)"
I hope this helps you.
#5 2022-09-07 16:27:01
Can you take a video of the boot messages, then play it back a frame at a time? Or post it here so someone with better eyes can try to read it?
#6 2022-09-07 20:46:17
nobodyuknow
@GlennW
Bingo (the first one). The error messages are the same.
[    0.264961] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.BCM5], AE_NOT_FOUND (20211217/dswload2-162)
[    0.265128] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20211217/psobject-220)
[    6.134372] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D008] at bit offset/length 128/8 exceeds size of target Buffer (128 bits) (20211217/dsopcode-198)
[    6.134558] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.134709] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.134888] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D008] at bit offset/length 128/8 exceeds size of target Buffer (128 bits) (20211217/dsopcode-198)
[    6.135068] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.135212] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.135559] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D008] at bit offset/length 128/8 exceeds size of target Buffer (128 bits) (20211217/dsopcode-198)
[    6.135767] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.135932] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.136124] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D008] at bit offset/length 128/8 exceeds size of target Buffer (128 bits) (20211217/dsopcode-198)
[    6.136322] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.136478] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.136665] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D009] at bit offset/length 136/8 exceeds size of target Buffer (136 bits) (20211217/dsopcode-198)
[    6.136862] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.137018] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.137205] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D009] at bit offset/length 136/8 exceeds size of target Buffer (136 bits) (20211217/dsopcode-198)
[    6.137402] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.137561] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.137765] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D008] at bit offset/length 128/8 exceeds size of target Buffer (128 bits) (20211217/dsopcode-198)
[    6.137991] ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[    6.138152] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20211217/psparse-529)
[   20.461856] rtw_8821ce 0000:03:00.0: failed to get tx report from firmware
[ 1362.038359] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 1668.022511] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 1712.054375] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 1918.042159] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 2206.038375] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 2664.117912] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 2961.901327] rtw_8821ce 0000:03:00.0: failed to send h2c command
[ 3370.966356] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 3588.022456] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 3622.042265] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 4027.990374] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 4325.014380] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 4669.014370] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 4989.013917] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 5094.037917] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 5778.101932] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 6453.973919] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 6515.990138] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 7508.029887] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 7579.029869] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 7697.082108] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 7766.998392] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 7783.029873] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 7850.042228] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 7908.021877] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8193.014399] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8220.053905] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8222.037922] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8336.021916] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8507.033918] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8559.009881] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8770.038370] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8805.045958] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8825.014373] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8830.966241] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 8854.998381] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9020.021916] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9042.037909] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9180.053884] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9202.041905] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9273.993881] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9340.021950] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9385.017888] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9512.985911] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9524.985880] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9568.993880] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
[ 9605.029869] rtw_8821ce 0000:03:00.0: firmware failed to leave lps state
Let me think about those messages. I have Devuan MATE installed on a different external SSD -- the one in question is Cinnamon, with both being Chimaera -- so I can compare the boots.
Another strangeness is that maybe last month I updated the BIOS to the most recent one (F.62). I tried reinstalling the previous one (F.61), but the error messages remained the same. I downloaded the last seven BIOS updates and I think I'll try each one, going back in time.
By the way, because of the Realtek wireless chipset, I installed linux-image-5.18.0-0.bpo.1-amd64_5.18.2-1~bpo11+1_amd64.deb. Otherwise there was no connectivity.
