#1 2022-08-30 16:00:34
wingcommander1999
[HowTo] Install VirtualBox 6.1.36 on DEVUAN 5
When installing virtualbox via .deb file retrieved from the site, an error appeared because a dependency was not satisfactory for the installation. (libvpx6)
For this we will download the missing dependency and install it using the devuan Package View site:
wget http://deb.devuan.org/merged/pool/DEBIAN/main/libv/libvpx/libvpx6_1.9.0-1_amd64.deb
Once downloaded, just open an terminal window:
sudo gdebi libvpx6_1.9.0-1_amd64.deb
After installing the missing dependency you can continue installing virtualbox.
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
#2 2022-08-30 16:34:17
Re: [HowTo] Install VirtualBox 6.1.36 on DEVUAN 5
If gdebi is used to install the VirtualBox .deb it will pull in libvpx6 from the repositories automatically. No need to do it yourself like some hair-shirted Slackware user.
This works for me:
apt install -s ./virtualbox-6.1_6.1.36-152435~Debian~bullseye_amd64.deb
Remove the -s option if you actually do want to install the world's worst virtualisation solution.
#3 2022-08-30 17:07:38
wingcommander1999
This works for me:
And then it can also happen that the right libssl dependency is missing:
wget http://deb.devuan.org/merged/pool/DEBIAN/main/o/openssl/libssl1.1_1.1.1o-1_amd64.deb
sudo gdebi libssl1.1_1.1.1o-1_amd64.deb
Daedalus / W11
#4 2022-08-30 17:15:09
Or you could add the unstable repositories and pin them to 100 so packages from there are treated like backports:
https://www.debian.org/doc/manuals/debi … le_literal
That would certainly be easier than adding a new thread every time a package is blocked from testing.
#5 2022-08-30 17:20:32
wingcommander1999
Thanks for the tip, I didn't know about this manipulation.
Daedalus / W11
#6 2022-08-30 17:23:34
Don't try it with the stable release though. It is only appropriate for testing.
#7 2022-08-31 12:32:31
Ogis1975
Why use this product of dubious quality when there is good quality and open source alternative-QEMU / kvm?
            ----+- Peter Kropotkin -+----
#8 2022-08-31 21:18:33
wingcommander1999
All my virtual machines are under virtualbox, when I was under mac I used vmware fusion.
But the idea of using qemu/kvm in the future is not distasteful.
Daedalus / W11
#9 2022-08-31 22:52:51
I used to use vBox, I thought it was really good. Generally I used to use it for one game "DiD's F22".
Once that game was irreversibly tanked remotely, I gave up on vBox.
But I remember struggling to get vBox configured and eventaually having a system that was reliable and flexible.
I was still using Mandriva in those days.
#10 2024-03-27 17:28:58
nahkhiirmees
I was able to download those libvpx6 and libssl with apt.
Temporarily changed sources.list to point into Chimaera instead of Daedalus.
Then install needed packages.
Copy the .deb - files under /var/cache/apt into a asfer location.
Uninstall those 2 packages.
Change sources.list back.
Install .deb - files with dpkg.
