First step install Linux Headers and compilation dependencies:
sudo apt install linux-headers-$(uname -r) build-essential libglvnd-dev pkg-config dkms -y
Second step blacklist the nouveau driver, create a blacklist file:
sudo nano /etc/modprobe.d/blacklist-nouveau.conf
In the file add the following and save the file:
blacklist nouveau
options nouveau modeset=0
Then regenerate the kernel initramfs:
sudo update-initramfs -u
Third step install the latests NvidiaGraphicsDrivers:
sudo apt install firmware-misc-nonfree nvidia-kernel-dkms nvidia-driver nvidia-cuda-toolkit nvidia-cuda-dev nvidia-settings nvidia-smi nvidia-xconfig nvidia-opencl-icd nvidia-opencl-common nvidia-detect -y
Reboot.
To view how version you have installed, just open an terminal and enter follow:
nvidia-smi
[Edit] After updating the repos there was a dependency error with the nvidia-settings package in the backports sources, to fix this incident it was enough to remove the backports source command.
It may happen that the persistenced daemon does not activate and need i386 binaries to work, it will then have to be done manually with the commands below:
sudo dpkg --add-architecture i386
sudo apt update
sudo update-rc.d nvidia-persistenced defaults
sudo service nvidia-persistenced start
Enjoy!
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
Registered here at the forum just to thank you @wingcommander1999 for this post.
My upgrade Chimaera -> Daedalus somehow botched my Nvidia driver install and your post saved me (after I had tried, unsuccessfully, to reinstall the drivers).
A couple of things worth noting for others: The repo "non-free-firmware" must be enabled in /etc/apt/sources.list in order to able to install the package firmware-nvidia-gsp (which is a requirement). Also, I just removed the package nvidia-persistenced without any visibly negative effects (so far).
