#1 2022-08-19 17:38:41
kapqa
(jessie to beowulf) restart / shtudown greyed out
Hello,
have upgraded to computer to Beowulf and
encountered the following
the "Restart" and "Shutdown" button is greyed out;
the computer is functioning normal well,
but i seem not be able to hibernate/suspend and restart / shutdown via the Applications Menu command.
Is there something i am missing?
have installed the Firmware-AMD-package.
Thanks.
https://i.imgur.com/UY4AZxB.png
#2 2022-08-19 21:55:28
Re: (jessie to beowulf) restart / shtudown greyed out
Make sure that policykit-1-gnome is installed.
See the section on Session Management and policykit backends in the beowulf release notes:
https://files.devuan.org/devuan_beowulf … _notes.txt
You might want to switch from consolekit to elogind.
