#1 2022-07-31 14:56:34
orto
USB full installation possible?
Distro-hopper here but only interested to run a full installation (NOT persistence) of Devuan on a USB (portable, bootable).
Is that possible?
And if yes, how would I go about doing this?
Thanks, guys!
#2 2022-07-31 17:07:36
Re: USB full installation possible?
Perfectly possible, I often do it with various distros. smile
Just plug in the pendrive, & use it as the disk to install to, only proviso, just make sure it is the one that has grub installed to it.
#3 2022-07-31 19:07:50
At least USB3.0 is strongly recommended.
F2FS is probably the best filesystem and it should be supported by GRUB >v2.04, which includes chimaera's version.
EDIT: looks like F2FS needs the extra_attr flag enabled for it to work as /boot so it would probably have to be created before running the installer (replace $label with the actual desired label for the partition):
# mkfs.f2fs -l $label -O extra_attr,inode_checksum,sb_checksum /dev/sdXY
#4 2022-08-01 04:41:29
For a UEFI system the installer does not ask for a target drive so "expert" mode must be used and the "force installation to removable loader location" GRUB option selected.
