#1 2022-07-25 19:10:28
giorgiob
[SOLVED] Chimaera Dual Boot with Existing Windows (GPT/EFI): No GRUB Menu
I am trying to install Devuan Chimaera on a Lenovo ThinkPad that has Windows 10 pre-installed.
I would like to have a dual boot system. I have done such installations many times with MBR but
I have no experience with EFI/GPT.
The SSD internal disk has a GPT-partitioning that initially looked like this:
/dev/sda1 1G Microsoft basic data
/dev/sda2 260M EFI System
/dev/sda3 500M Microsoft reserved
/dev/sda4 ~220 G Microsoft basic data (drive C:)
/dev/sda5 953 M Microsoft basic data
I have shrinked partition 4 from Windows and then installed Devuan using a netinstall image.
From the installer, I have created a 1G ext4 boot partition (/dev/sda6) and a 124 G encrypted partition (/dev/sda7) in the free space.
Then I have used the encrypted partition as a volume for LVM and put a swap and a root partition in it.
The installation seemed to work. I had a warning from GRUB but I thought everything would be OK.
But when I rebooted the laptop I got not GRUB-menu: the system just booted into Windows.
So I read some domentation (https://www.gnu.org/software/grub/manual/grub/grub.html, Section 4.1 Installing GRUB using grub-install)
and I rebooted the installation USB-stick into recovery mode and opened a shell in the root filesystem of the installation.
There; I followed the instructions from the GRUB documentation and made a directory
/boot/efi
and mounted the EFI System partition (/dev/sda2) under /boot/efi. Then I ran
# update-grub
# grub-install --target=x86_64-efi
This seemed to work, even though the second command printed a warning: EFI variables are not supported on this system.
Anyway, the EFI System partition now contained a directory:
/EFI/debian
or
/boot/efi//EFI/debian
from Devuan.
So, I left the recovery shell and rebooted but I still got no GRUB-menu: The computer booted directly into Windows as if GRUB were not installed.
Do you have any hints? I can reinstall from scratch and post any GRUB warnings here in case you need more detailed information.
#2 2022-07-25 19:30:37
Re: [SOLVED] Chimaera Dual Boot with Existing Windows (GPT/EFI): No GRUB Menu
Well, the error you got saying "EFI variables are not supported on this system." tells me you run into the same problem I have seen several times with Chimaera. Have a read through this thread: https://dev1galaxy.org/viewtopic.php?id=4496
I guess you need to mount the efivars before running the grub-install.
Good luck, rolfie
#3 2022-07-25 19:59:54
#4 2022-07-25 21:02:30
giorgiob
Thanks a lot for the hints.
I have booted into recovery mode: There is indeed no directory /sys/firmare/efi, neither in the installer console nor in the chroot shell.
I tried
# mount -t efivarfs efivarfs /sys/firmware/efi/efivars
In the chroot shell this gives:
mount: /sys/firmware/efi/efivars: mount point does not exist
I am not allowed to create the mount point:
# mkdir -p /sys/firmware/efi/efivars
mkdir: cannot create directory `/sys/firmware/efi': Operation not permitted
Trying to mount from another console (without chroot) gives the following error:
mount: mounting efivarfs on /sys/firmware/efi/efivars failed: No such file or directory
#5 2022-07-25 23:07:28
perhaps it works with
# modprobe efivars
#6 2022-07-26 05:44:05
If /sys/firmware/efi/ does not exist then the system is not booted in UEFI mode and no new NVRAM boot entries can be made.
@OP: make sure "Legacy" mode (CSM) is disabled and UEFI is enabled in the firmware ("BIOS") options.
As a last resort Windows can chainload Devuan with this command (run as Administrator):
bcdedit /set "{bootmgr}" path "\EFI\debian\grubx64.efi"
#7 2022-07-26 08:24:59
giorgiob
That was the problem! I have enabled both legacy and UEFI in the BIOS, and legacy had higher priority so the installation USB stick was booted in legacy mode.
After changing the priority, I started the USB-stick in recovery mode and the efi directory was there. However, efivars had not been mounted and I had to mount it by hand. After that
# update-grub
did the job: I now get the GRUB menu with Devuan as default entry and from there I can also boot into Windows.
Thanks a lot for all the answers!
