#1 2022-06-29 12:30:00
kyuss
Encrypted installation + dual boot
First, hello im new here, so hello first of all and devuan is a great systemd free fork of debian.
Ive recently installed devuan 4 on my drive and wanted to know if its possible to have an encrypted dual boot scenario as follows?
devuan 4 boot partition = /dev/sda1 (ext2)
devuan 4 root partition = /dev/sda2 (encrypted luks ext4)
other linux = /dev/sda3 (encrypted luks ext4)
Want i want if possible is to add a partition and install anther linux like say voidlinux and have it encrypted as well.
scheme layout would be like so,
devuan = /dev/sda1 - /dev/sda2
voidlinux = /dev/sda3
both /dev/sda2  and /dev/sda3 would be using just plain dm-crypt.
Can this be achieved via the grub boot loader or do i need to use some other method?
I know how to setup a plain dm-crypt archlinux installation so i have some knowledge, but cant find any info if this is possible what im asking here?
May the fork be with you!
#2 2022-06-29 17:47:53
Re: Encrypted installation + dual boot
I think the easiest way to do it is to make a fourth partition to use as a separate /boot for the second linux. Then decide which linux will rule grub and only let that one do grub-install (or do it last from that one.)
Whichever one rules grub, you will have to create a boot entry manually for the other one, because os-prober won't find encrypted root filesystems. Put your entries in /etc/grub.d/40_custom and run update-grub to generate the boot menu.
I think it's possible to let the two systems share a boot partition, but there may be some tricks involved to avoid problems if/when grub packages are updated. It's also possible to have the /boot directory inside the encrypted root partition if /etc/default/grub has a line with GRUB_ENABLE_CRYPTODISK=y.
Edit: Here are a couple of old discussions that might be helpful:
https://forums.debian.net/viewtopic.php?p=352368
https://forums.debian.net/viewtopic.php?f=16&t=115362
#3 2022-06-29 20:16:22
Got Arch, Beowulf and Chimaera working independently from each other, all encrypted. Boundary conditions: modern X570 MB configured to UEFI only, NVME gpt partitioned. Arch w/o separate /boot, Beowulf and Chimaera with separate individual /boot partitions. Per default Chimaera is booted, if I want Beowulf or Arch I need to use the F8 key on my MB to select the OS to be started.
#4 2022-06-30 11:50:30
kyuss
Appreciate the info, thanks fsmithred and rolfie. I will give your idea a try fsmithred on a spare disk i have.
Rolfie i only have an old bios boot machine so uefi is a no go for me, thanks anyway.
