#1 2022-05-28 09:43:11
jaromil
[SOLVED] APT install timeout
Hello everyone!
I had this problem using Devuan on Docker images and bare-metal installations when connecting to certain mirrors and even on pkgmaster.
Not sure if anyone has a better solution, so far mine is this adding an "Acquire::Retries" policy of "5" to apt.conf.d
echo "Acquire::Retries \"5\";" | sudo tee /etc/apt/apt.conf.d/avoid-timeouts
Hope this helps anyone experiencing the same problem.
ciao
E-Mail: J @ Dyne.org
GPG fingerprint: 6113 D89C A825 C5CE DD02  C872 73B3 5DA5 4ACB 7D10
#2 2022-05-28 13:48:31
hevidevi
Re: [SOLVED] APT install timeout
Thanks, ive experienced this. What usually works for me is ctrl -c the install/update in the terminal and try again. Usually second try works. But this little one liner is a gem.
#3 2023-09-19 21:34:03
Joerg_rw
rather
tee --append
, just in case...?
