#1 2022-03-12 21:49:23
apparmor foisted on, by default?
A question to something that has baffled me for the longest while ...
Why (in #$%&@'s name) does upgrading the kernel require that apparmor be installed?
Just whose bright idea was this?
And more important yet: is it in line with Devuan policies?
Start-Date: 2022-03-12  09:34:39
Commandline: apt upgrade
Install:
linux-headers-4.19.0-19-common:amd64 (4.19.232-1, automatic)
linux-headers-4.19.0-19-amd64:amd64 (4.19.232-1, automatic)
linux-image-4.19.0-19-amd64:amd64 (4.19.232-1, automatic)
apparmor:amd64 (2.13.2-10, automatic)   <-------------------------  why?
Can't this be avoided when packaging for Devuan by removing it from the recommends list?
Just asking, because choice and all that.
#2 2022-03-12 21:59:04
Re: apparmor foisted on, by default?
Yes, this could be avoided in packaging, but I doubt you can change the debian devs on this. And nobody around here is going to fork the kernel. (that's my prediction)
You can avoid that and a lot of other cruft with this:
cat /etc/apt/apt.conf.d/00norecommends
APT::Install-Recommends "no";
I don't know if adding '--no-install-recommends' will work with 'apt upgrade'. If so, that's another way to avoid it.
#3 2022-03-12 22:58:05
fsmithred wrote:
... this could be avoided in packaging, but I doubt you can change the debian devs ...
On this or most anything, methinks.
I fear that they cannot help it.
They've all been inbued with the same dumb-down KoolAid.
fsmithred wrote:
... nobody around here is going to fork the kernel.
Ahh ...
If forking is required, I cannot but agree with you.
cat /etc/apt/apt.conf.d/00norecommends APT::Install-Recommends "no";
Right ...
Maybe add this as a commentary to the Release Notes most no one reads?  8^/
eg:
If you do not want the apparmor crap foisted on you without your knowledge when upgrading etc., etc., ...
NB:
For some reason it didn't work from the cmd line as root.
So I just created the file and then edited it.
fsmithred wrote:
... if adding '--no-install-recommends' will work with 'apt upgrade'.
Probably.
I'd also have to change the default /etc/apt/apt.conf.d/99synaptic to false.
I really find it quite tiresome/annoying to have to be on alert for this everytime I upgrade the kernel.
It should not be so.
But then, here we are.
Thanks a lot for your input.
I'll follow your suggestion to avoid this and all recommends in a system-wide manner.
A sort of 'Kill the dog and get rid of the rabies' solution.
Well done.  8^D
#4 2022-03-18 20:34:27
rbit
An alternate option for this particular case (apparmor) would be to create a file, e.g. /etc/apt/preferences.d/noapparmor
Contents:
Package: apparmor*
Pin: release n=beowulf
Pin-Priority: -1
Change the release name if you're not using beowulf.
#5 2022-03-18 21:13:28
rbit wrote:
An alternate option for this particular case ...
Hmm ...
No thanks.
I'd prefer that any and all recommends be something I get to consider installing to then decide and not something that is installed because some Debian packager though it was a good idea.
That is how the Linux bloat we have today started ...
I think that a system-wide block on recommends is a great idea.
Of course, YMMV.
Thank you for your input.
