#1 2022-02-24 04:38:35
Ron
[SOLVED] Getting "Lock Version" in Synaptic to work
I like an older version of gnome-sudoku than the one in chimaera's repo, so I had that particular older one installed via a .deb file, then in Synaptic Package Manager I had it marked as "Lock Version" under Package in the menu. I know it got marked because the icon changed to "Installed (locked to current version)" in the icon legend. However, the last time I did an upgrade gnome-sudoku got updated along with all the rest that had updates [ironically it still has the "Installed (locked to current version)" icon]. Did I miss a step, or am I misunderstanding what Lock Version does? Once I go back to the older version is there a way I can prevent gnome-sudoku from updating again?
#2 2022-02-24 06:54:04
Re: [SOLVED] Getting "Lock Version" in Synaptic to work
Read here about APT pinning:
https://dev1galaxy.org/viewtopic.php?id=3126
#3 2022-02-24 09:42:36
MLEvD
apt-mark hold <package>
command line apt ignores synaptic locking.
#4 2022-02-24 16:57:15
Ron
I update via Synaptic, never from the terminal, so I don't see how this applies to me? I want Synaptic to not update sudoku, which is what I thought Lock Version was supposed to do. In Synaptic is there a way to pick and choose from among the list of updates that are presented (when there are updates)?
#5 2022-02-24 22:54:21
Yes, it was. But this way failed, and therefore we are suggesting more reliable ways to prevent gnome-sudoku from being upgraded:
1) Via APT pinning. Edit a file /etc/apt/preferences/01nosudoku and write:
Package: gnome-sudoku
Pin: origin ""
Pin-Priority: -1
     Run apt-get update to be effected.
2) As MLEvD pointed out:
# apt-mark hold gnome-sudoku
#6 2022-02-24 23:26:45
Ron
It appears to have worked. Thanks, to both of you.
BTW, there was no "preferences" folder in /etc/apt, so I created one. Is that normal? There is a "preferences.d" folder.
#7 2022-02-25 19:37:01
I forgot the extension. So, you don't need to create any additional folder, because /etc/apt/preferences.d is the right place to edit the file.
#8 2022-02-25 23:43:42
Ron
Well everything seems to be working right. I had some updates today, and sudoku was marked as not to be upgraded. Everything else updated okay. Should I just leave well enough alone, or put that file in preferences.d and delete the preferences folder I created?
#9 2022-02-26 10:21:37
Either location should work.
Check the pinning with
apt policy
apt policy gnome-sudoku
I would consider running the program from a chroot because pinning makes me nervous but that would take significantly more disk space.
#10 2022-02-26 14:14:44
Ron
apt policy
Here's the output:
$ apt policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 100 http://deb.devuan.org/merged chimaera-backports/non-free amd64 Packages
     release v=4.0,o=Devuan Backports,a=stable-backports,n=chimaera-backports,l=Devuan Backports,c=non-free,b=amd64
     origin deb.devuan.org
 100 http://deb.devuan.org/merged chimaera-backports/contrib amd64 Packages
     release v=4.0,o=Devuan Backports,a=stable-backports,n=chimaera-backports,l=Devuan Backports,c=contrib,b=amd64
 100 http://deb.devuan.org/merged chimaera-backports/main amd64 Packages
     release v=4.0,o=Devuan Backports,a=stable-backports,n=chimaera-backports,l=Devuan Backports,c=main,b=amd64
 500 http://deb.devuan.org/merged chimaera-updates/main amd64 Packages
     release v=4.0.0,o=Devuan,a=stable-updates,n=chimaera-updates,l=Devuan,c=main,b=amd64
 500 http://deb.devuan.org/merged chimaera-security/main amd64 Packages
     release v=4.0,o=Devuan,a=stable-security,n=chimaera-security,l=Devuan-Security,c=main,b=amd64
 500 http://deb.devuan.org/merged chimaera/contrib amd64 Packages
     release v=4.0,o=Devuan,a=stable,n=chimaera,l=Devuan,c=contrib,b=amd64
 500 http://deb.devuan.org/merged chimaera/non-free amd64 Packages
     release v=4.0,o=Devuan,a=stable,n=chimaera,l=Devuan,c=non-free,b=amd64
     release v=4.0,o=Devuan,a=stable,n=chimaera,l=Devuan,c=main,b=amd64
Pinned packages:
     refractainstaller-base -> 9.5.6 with priority 1001
     refractainstaller-gui -> 9.5.6 with priority 1001
and
$ apt policy gnome-sudoku
gnome-sudoku:
  Installed: 1:3.22.2-1
  Candidate: 1:3.38.0-1
  Version table:
     1:3.38.0-1 500
 *** 1:3.22.2-1 100
Why does pinning make you nervous? My concern is just to be sure that nothing else gets blocked from updating.
#11 2022-02-26 15:09:39
gnome-sudoku:
  Version table:
     1:3.38.0-1 500
 *** 1:3.22.2-1 100
There is no pinning for that package. If you run apt update followed by apt list --upgradable I think gnome-sudoku will still be marked for upgrade to the chimaera version.
The apt-mark hold suggestion doesn't work either in my testing but this does:
Pin: version 1:3.30.0-2
Pin-Priority: 501
^ Save that under /etc/apt/preferences.d/gnome-sudoku.pref, run apt update and check the Candidate line in the output of apt policy gnome-sudoku. It should prefer the old version with that setting.
The man page states that a pin value of 1001 would be needed because the beowulf version constitutes a downgrade but that doesn't seem to be the case in my tests with a Debian bullseye chroot. If your system behaves differently please report back, I would appreciate the feedback. TIA.
If you want to keep the package updated from beowulf then add these lines to /etc/apt/sources.list:
deb http://deb.devuan.org/merged beowulf main
deb http://deb.devuan.org/merged beowulf-updates main
deb http://deb.devuan.org/merged beowulf-security main
Then change the Pin: version line in /etc/apt/preferences.d/gnome-sudoku.pref to
Pin: release beowulf
And remember to run apt update afterwards.
Because it's very complicated to use (see apt_preferences(5) for the official documentation, the Debian wiki page is bollocks) and it's far too easy to break your system if you don't know what you're doing.
I've just got the Debian buster version of gnome-sudoku running from a chroot in my Alpine system with no issues but the chroot takes up almost a gigabyte of disk space, which is ridiculous.
#12 2022-02-26 15:19:26
Ron
I only update via Synaptic, and here's what happens in it. It doesn't get updated. But are you saying if I do an update via the terminal it will get updated?
This is what I got from your commands:
ron@ron:~$ sudo apt update
[sudo] password for ron:
Hit:1 http://deb.devuan.org/merged chimaera InRelease
Get:2 http://deb.devuan.org/merged chimaera-security InRelease [21.5 kB]
Hit:3 http://deb.devuan.org/merged chimaera-updates InRelease
Hit:4 http://deb.devuan.org/merged chimaera-backports InRelease
Fetched 21.5 kB in 2s (9,148 B/s)
1 package can be upgraded. Run 'apt list --upgradable' to see it.
ron@ron:~$ apt list --upgradable
Listing... Done
gnome-sudoku/stable 1:3.38.0-1 amd64 [upgradable from: 1:3.22.2-1]
N: There is 1 additional version. Please use the '-a' switch to see it
#13 2022-02-26 15:25:58
Yes, apt upgrade would bring the gnome-sudoku package up to the chimaera version. Use my suggested /etc/apt/preferences.d/gnome-sudoku.pref file to prevent that.
I have no idea about Synaptic or how that works, sorry. I never use it.
#14 2022-02-26 15:34:34
Ron
I added the file you said. I changed the version from what you wrote to this 1:3.22.2-1 because this is the version I'm using. I ran the commands and this is what happened:
Fetched 21.5 kB in 3s (7,144 B/s)
All packages are up to date.
ron@ron:~$ apt policy gnome-sudoku
gnome-sudoku:
  Candidate: 1:3.22.2-1
  Version table:
     1:3.38.0-1 500
 *** 1:3.22.2-1 501
Is everything now correct?
#15 2022-02-26 15:36:44
Looks good to me :-)
#16 2022-02-26 15:45:40
Ron
Great. Just one more thing. Now this is what I get in Synaptic. It shows the old version that I use as the latest version. Does this mean I can undo the first thing I did earlier? Or should I just leave well enough alone?
#17 2022-02-26 16:01:42
Check
dpkg --get-selections gnome-sudoku
I think both Synaptic's package lock option and apt-mark hold will change that setting to
gnome-sudoku					hold
To confirm this run
sudo dpkg --set-selections <<<"gnome-sudoku install"
And check dpkg --get-selections gnome-sudoku, apt-mark showhold and Synaptic itself to see if this changes the "Latest Version" shown in your screenshot.
Revert the change with
sudo dpkg --set-selections <<<"gnome-sudoku hold"
Perhaps that is needed as well as APT pinning for it to work with both Synaptic and apt/apt-get/aptitude.
EDIT: it seems aptitude uses either the dpkg database or APT's pin values. This is confusing.
#18 2022-02-26 16:24:13
Ron
Check
While waiting for your reply, I went ahead and deleted the preferences folder I created with that file in it, and kept the file you recommend in preferences.d, then rebooted. Synaptic is still showing the old version of sudoku I use as the latest version. I also checked apt update and apt policy gnome-sudoku and that checked out good also. So I guess all is well??
#19 2022-02-26 16:32:21
I think so, yes.
Looks like Synaptic & apt-mark both use the dpkg database whereas apt & apt-get will check the pinning and aptitude will accept either input.
#20 2022-02-26 16:36:14
Ron
I think so, yes.
Great. I will mark as solved. Thanks once again HoaS for your help. Thanks also to aitor; your way did stop Synaptic from updating it.
