#1 2022-02-10 20:11:56
zen253230
[SOLVED] How to remove elogind postinstall in Xfce4 in order to use consolekit2
Hello everyone,
I just couldn't find the answer to my question on the forum!
For sure not everybody is willing to remove elogind but Linux is choice so I'd like to use consolekit 2 instead as advertised in devuan chimaera release notes.
Problem is even when I launch xfce4 with parameters
startxfce4 --with-ck-launch
elogind is still running in the background...
So removing elogind crashes everything sad
But it is said that both ck2 and elogind are mutually exclusive.
So is there a step by step guide to do it post installation?
Thank you in advance
#2 2022-02-11 14:21:51
Re: [SOLVED] How to remove elogind postinstall in Xfce4 in order to use consolekit2
I'm not aware of any guide for doing this, so I tried it. To be safe, I dropped to console first and stopped the slim display manager.
### ctrl-alt-F2 and then log in as root.
/etc/init.d/slim stop
apt remove elogind libpam-elogind consolekit+ libpam-ck-connector+
That replaced elogind with consolekit and removed a bunch of other stuff, including gvfs, udisks2 and network-manager. I replaced network-manager with connman and set connman-ui-gtk to start with the desktop.
apt install connman connman-ui connman-gtk
The user can no longer shutdown or reboot from the desktop. I assume that mounting of removable media is also gone. I don't know if there are fixes for this.
An alternative approach would be to do a minimal install, switch to consolekit first, and then start adding things.
#3 2022-02-11 14:39:19
For user to mount removable media, you could install pmount and either spacefm or pcmanfm. You may need to install without Recommends.
apt --no-install-recommends install <package>
If you want to avoid installing elogind by mistake, you could pin it by creating a file in /etc/apt/preferences.d/ with the following:
Package: *elogind
Pin: version *
Pin-Priority: -1
#4 2022-02-11 15:58:17
zen253230
Thank you very much!
Exactly what I was looking for
I'll give it a try asap
#5 2022-02-12 14:21:29
zen253230
Ok so I tried to follow your instructions.
Trying at first to stop slim but it said "failing". It lasted for a while complaining about
iwlwifi no beacon heard and the time event is over already
then stopped at last...Nevertheless I went further first by installing consolekit and associated libpam
apt-get install consolekit libpam-ck-connector
It went on flawlessly uninstalling some other packages by the way but as soon as I uninstalled elogind
apt-get remove elogind
I lost my wifi network. I had to manually edit the network configuration following devuan instructions
nano /etc/network/interfaces
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
      wpa-ssid myssid
      wpa-psk mypassphrase
then save with Ctrl+X and then
ifup wlan0
Network was back
Concerning pmount and spaceman it works great so thank you again !
#6 2022-02-12 15:08:54
zen253230
Ok so now I've got one last problem with connection manager. I installed it successfully (in fact I started to mix it up with conman with one n !)
Starting the system, I've got no internet connection with wifi even when launching connman settings and activating wifi : it shows no wifi connections around !
The only way is to start the system without
auto wlan0
and then manually edit /etc/network/interfaces and add it after devuan launch.
Then after
ifup wlan0
network is back...otherwise if I leave it at start of devuan it shows me an error about already configured network
I must say I'm quite a newbie so any help is welcome
#7 2022-02-12 16:12:27
If wlan0 is listed in /etc/network/interfaces then connman will ignore it. Use either ifupdown or connman, not both.
EDIT: if you're running chimaera then I would recommend iwd instead:
# apt install iwd orphan-sysvinit-scripts wpa_supplicant- connman- dhclient-
# cp /usr/share/orphan-sysvinit-scripts/iwd /etc/init.d/
# update-rc.d iwd defaults
Then use iwctl to configure your wireless connection and add this to /etc/iwd/main.conf:
[General]
EnableNetworkConfiguration=true
And add a network configuration stanza to /var/lib/iwd/<name of SSID>.psk, for example:
[IPv4]
Address=192.168.0.23
Netmask=255.255.255.0
Gateway=192.168.0.1
The wlan0 lines can be removed from /etc/network/interfaces once iwd is configured.
See also https://wiki.debian.org/WiFi/HowToUse#Using_IWD
#8 2022-02-12 16:16:23
If you use a gui frontend network app like connman or network-manager, you should not configure the network in /etc/network/interfaces. They will likely fight with each other. Do one or the other.
