how to increase the size of texts in (l)xterm through the command x-terminal-emulator?
does a simple option in the commando line or link ( x-command-emulator is only a link! ) exist?
https://dev1galaxy.org/viewtopic.php?id=4781
Use ~/.Xresources to set the text size in xterm.
Here's my font configuration:
*vt100.faceName: mono:size=11
See the RESOURCES section of man xterm for a full list of options.
Or use this:
xterm -fa mono:size=11
It would not be appropriate to apply this option to x-terminal-emulator because it would break if that alternative was changed to point to a different emulator.
