#1 2022-01-04 16:35:57
bai4Iej2need
[SOLVED] apt-cacher-ng fails to download most of the time
since about Xmas my automatic updating  via apt-cacher-ng fails.
It fails to download the release files, packages list and the packages completely or sometimes it is extremely slow.
retrieving the files via a browser or with aptitude excluding the apt-cacher-ng works without problem.
this is an error , which comes up from time to time now after 5 month of no trouble .
aptitude update
Err http://deb.devuan.org/merged beowulf InRelease
  Connection failed [IP: 127.0.0.1 3142]
Err http://deb.devuan.org/merged beowulf-security InRelease
Get: 1 http://deb.devuan.org/merged beowulf-updates InRelease [26.7 kB]
Get: 2 http://deb.devuan.org/merged beowulf-backports InRelease [26.9 kB]
Fetched 53.6 kB in 2min 31s (353 B/s)
W: Failed to fetch http://deb.devuan.org/merged/dists/beowulf/InRelease: Connection failed [IP: 127.0.0.1 3142]
W: Failed to fetch http://deb.devuan.org/merged/dists/beowulf-security/InRelease: Connection failed [IP: 127.0.0.1 3142]
W: Some index files failed to download. They have been ignored, or old ones used instead.
so sometimes it works, sometimes not. what causes it?
broken by design :
#2 2022-01-04 16:54:47
bai4Iej2need
Re: [SOLVED] apt-cacher-ng fails to download most of the time
https://unix.stackexchange.com/question … pdate-acgn
: acng.conf in lines
48:BindAddress: 127.0.0.1 192.168.4.1
353:ConnectProto: v4
fixed it.
broken by design :
#3 2022-08-27 23:12:06
webman
Hallo!
I have the same problem.
The answer does'nt fit.
I have ipv6 disabled on all computers (acp-cacher-ng, proxy, chimera-host).
Just to be sure, I applied the same settings like in your answer, but no changes.
Additionally, on the chimera-box I have a lxc-container (running debian buster), which updates fine.
I found a similar post regarding ubuntu and then, I made a try to load one of the failing urls
using curl over acng:.
curl -p http://192.168.12.132:4455 http://pkgmaster.devuan.org/merged/pool/DEBIAN-SECURITY/updates/main/x/xorg-server/xvfb_1.20.11-1%2bdeb11u2_amd64.deb
curl: (56) Received HTTP code 403 from proxy after CONNECT
Went to the acng-box and I see the response from the final squid-proxy and I get:
<p>Some aspect of the requested URL is incorrect.</p>
<p>Some possible problems are:</p>
<ul>
<li><p>Missing or incorrect access protocol (should be <q>http://</q> or similar)</p></li>
<li><p>Missing hostname</p></li>
<li><p>Illegal double-escape in the URL-Path</p></li>
<li><p>Illegal character in hostname; underscores are not allowed.</p></li>
</ul>
Changing apt-settings from acng to squid, doing update, changing back to acng following an upgrade
works.
There were wrong urls/hostnames in the apt-sources (which were probably very old, because
it is an experiment (which I use to see devuan instead of debian/systemd).
Hope this helps someone, wo felt over this too.
Regards,
Manfred
