#1 2022-01-03 16:34:21
lalberts
adduser ?
Hello,
thanks for making devuan available.. i never could get through systemd.. some easy thing that used toi be a long time ago, like post-logout-scripts.
so i am moving from debian to devuan.. at least i try with my little linux knowledge.
Could make easily a boot stick with the chimaera iso.
Booted right away on my old TP-x200s. All the UEFI stuff i did not yet assimilate neither. so i made my new ssd as a msdos partition-map,
and 2 or 3 try&error until my partitions were set right.. why this target-home  or target-boot names?
somewhen I must have don a mistake when answering at the installation-procedure.
installation went through..first boot without boot-stick.
well the username was not available?  but  I had to use the hostname as username? password was then OK (the one made for the new user)
going into a sheel try to correct this username situation..
adduser ? no found.. ok, go as 'SU'.. well again not found.. so the PATH environment must not be set correctly..
what happened that user and passwd went wrong?
thanks
lukas
#2 2022-01-03 16:40:50
Re: adduser ?
Please check the Release Notes (https://files.devuan.org/devuan_chimaer … _notes.txt) for the path/su issue.
How did you do your install? Sounds a bit like Expert Mode and leaving out one or the other step ...
#3 2022-01-03 18:14:38
Re: adduser ?
Easiest way to get up & running is to install from the 'live' version - basically, everything that works on Debian also works with Devuan.
(Try sudo useradd.)
#4 2022-01-04 08:44:37
lalberts
Re: adduser ?
Thanks for your answers.
I did use the installer tool from the iso-live-version-boot-stick.
after install i had:
x200s:x:1000:1000:lukas,,,:/home/x200s:/bin/bash
using sudo adduser lukas  added me:
lukas:x:1001:1001::/home/lukas:/bin/sh
but the login process fails..
did not  make a home directory..
i will handle this, with time
thanks
lukas
