#1 2021-12-28 09:10:08
kapqa
AMDGPU-PRO for hardware accelleration/ Devuan 4.0
Hello,
i have seen this post here
https://wiki.debian.org/AMDGPUDriverOnStretchAndBuster2
and am wondering if there is possibility to install the latest AMD GPU-PRO Drivers also on Devuan 4.0 running Kernel 5.x.
Thank you.
#2 2021-12-28 10:20:03
Re: AMDGPU-PRO for hardware accelleration/ Devuan 4.0
Read the warning at the top of your linked page. I do not recommend that method because it replaces the entire graphics stack — the PRO drivers are only useful for OpenCL, they perform worse then the open source version for everything else.
See https://dev1galaxy.org/viewtopic.php?id=4688 & https://gitlab.com/BCMM/amdgpu-opencl-on-debian for a way to install the OpenCL part of the PRO drivers so you don't ruin performance for other applications but be aware that it might wreck your system.
#3 2021-12-28 14:15:44
kapqa
Hello,
head_on_a_Stick,
thanks for the effort,
but its not functioning.
let§s hope someone brillian come up with an one-liner to install the amdgpu-pro driver (with --opencl=legacy) also for debian/devuan.
#4 2021-12-28 14:56:35
Look out for a rocm package in the unstable branch, as per the last post in my linked thread.
#5 2021-12-31 14:42:39
kapqa
Thanks, do i need to upgrade from Devuan 4.0 to Devan 5.0 to get this package / Hardware accelleration?
#6 2021-12-31 17:11:12
Read the link.
#7 2022-01-02 11:08:11
kapqa
sorry, but i find the information confusioning,
i any case, it seems that i would not need the "rocm" package as the graphics card installed is older (polaris)
https://amdgpu-install.readthedocs.io/e … cript.html
    ROCr: Provides support for Vega 10 and newer hardware.
    Legacy: Provides support for hardware older than Vega 10.
        (Proprietary, requires EULA acceptance)
#8 2022-01-02 12:26:29
kapqa
thanks head_on_a_stick,
have to retract my previous post, it seems to function actually,
the polars gets recognized "properly",
Platform #0: AMD Accelerated Parallel Processing
 `-- Device #0: gfx804
https://imgur.com/a/YQHTE02
Thank you very much!
EDIT: it "seems" to function, probably, is still better wording. don§t think that pulling a 29,2 MB .deb of a 685 MB Archive is capable of doing it the proper way as it supposed, but for some usecases it might be OK.
#9 2022-01-02 12:48:01
kapqa
Unpacking amf-amdgpu-pro:amd64 (21.20-1292797) ...
dpkg: dependency problems prevent configuration of amf-amdgpu-pro:amd64:
 amf-amdgpu-pro:amd64 depends on vulkan-amdgpu-pro; however:
  Package vulkan-amdgpu-pro is not installed.
 amf-amdgpu-pro:amd64 depends on opencl-rocr-amdgpu-pro; however:
  Package opencl-rocr-amdgpu-pro is not installed.
dpkg: error processing package amf-amdgpu-pro:amd64 (--install):
Processing triggers for libc-bin (2.31-13+deb11u2) ...
#10 2022-01-07 13:02:18
The rocm package is not available yet. It might be available in the future.
