Followed the guide on upgrade and when logging in to KDE blank screen with error message, no shell present. I can run Alt+ F2 to run Konsole and launch applications but shell is missing so no desktop. Help!
Update 13.12.2021: OK the full error message is a knonw KDE error/bug in other OS's:
Message was "all shell packages missing.Contact your distribution".
I used Alt+ F2 to launch Konsole and was able to get firefox up and running and my /home folder still intact which is the main thing. When I tried to launch
startx from the terminal it launched LXQt and asked which manager I wanted to use. I selected kwin but still black desktop.
I followed the commands as laid out on the main page of Devuan. The only messages I could see were medium security warnings and the principle one I amended as advised by the warning was the command
chkboot -uafter
apt-get updateAfter some more whirring in the terminal I got the error message
Not enough space in /var/cache/apt/archiveI did some searching and applied the command
apt-get autocleanI then followed the instruction from the Devuan upgrade guide:
apt-get dist-upgradeI also ran the commands from the guide:
apt-get autoremove --purgethen once more
apt-get autocleanEverything appeared fine until I rebooted. It was clearly indicated that I was using version 4 of Devuan at tty in terminal. KDE was nowhere to be found in the DE options, only MATE and LXQt and Devuan default (LXQt).
I attempted:
sudo apt-get install kde-fullThis pulled all KDE packages into the system.
I still only got the tty at login and after I logged in at the terrminal I attempted 'startx' but no response.
I then remembered I had timeshift and chose advanced recovery mode for 4.19 kernel at boot time.
I restored the image taken at 12.02 yesterday.
Upon reboot still tty login. On attempting to run
startxI get the error message that glibc 2.6 is not present needed to run startx - message not complete but on searching glibc is critical in running everything and can be a major issue following an upgrade (other OS's).
What to do now?
[This post posted from FerenOS drive, accessing Devuan /home folder]
Update 13.12.2021: the glibc error message in full when attempting to run 'startx' after a timeshift --restore (also /var/cache/apt/archives full even after deleting from other OS):
/usr/lib/xorg: /lib/x86_64-linux-gnu/libc.so.6: verssion 'GLIBC_2.30' not found (required by /lib/x86_64-linux-gnu/libsystemd.so.0)
xinit: giving up
xinit: unable to connect to X server: connection refused
xinit: server errorLast edited by swarfendor437 (2021-12-18 19:33:53)
After attemtping various solutions to no avail, my only option forward was to use FerenOS to access my /home folder and save to newly purchased WD Elements 4 Tb hard drive. I have wiped the drive and installed Devuan 4 - the only glitch with the install is that whilst I had chosen UK and British English inputs, on first logon I had to use US layout for one of the symbols in the password! This has now resolved itself so will mark as "Solved" but it wasn't really.
