#1 2021-11-09 03:07:10
Ron
Two more issues on new Devuan 4 install
I'm trying to add the ppa for inxi sudo add-apt-repository ppa:unit193/inxi but I keep getting this:
Ron@Ron:~$ sudo add-apt-repository ppa:unit193/inxi
[sudo] password for Ron:
sudo: add-apt-repository: command not found
It worked on ascii; don't know why it's not working on 4.0.
The other issue is that when I open a sound app (Audacity, SMPlayer, start up sound) I'm getting an annoying POP sound. It just pops when you open the app. After that it's okay. Any ideas on this?
[I'm still having the screen tearing issue mentioned in my other post.]
#2 2021-11-09 05:10:31
macboy001
Re: Two more issues on new Devuan 4 install
from a quick look in order to get the use of add-apt-repository you need to apt install software-properties-common
HTH
regards
Bryan
#3 2021-11-09 06:56:55
inxi is in the normal Devuan repository.
#4 2021-11-09 08:29:41
PPAs are not compatible with Devuan and can break it completely.
See https://wiki.debian.org/CreatePackageFromPPA for an alternative method (but not for inxi, as rolfie notes).
