#1 2021-10-16 18:07:35
danista
how to boot from netinst.iso?
I downloaded the new version but I can not start the computer from the installation disk devuan_chimaera_4.0.0_amd64_netinstall.iso
#2 2021-10-17 11:42:32
hevidevi
Re: how to boot from netinst.iso?
how did you copy over the iso file to the disk and what medium did you use. By disk do you mean usb disk or compact disk (cd rom)? Usually you have to set the bios to boot from usb or cd, on mine i have to press F10 when the computer boots up to get to boot menu which lists what disks or medium boot from.
This is what i do to clear usb disk before i copy over the iso file to make sure there is no old gpt data or bios mbr data which could interfere with a successfull usb boot.
as root user..
# wipefs --all /dev/sdb
# sgdisk --zap /dev/sdb
then dd to usb disk.
# dd if=devuan_chimaera_4.0.0_amd64_netinstall.iso of=/dev/sdb oflag=sync status=progress bs=4M
#3 2021-10-17 12:04:46
danista
I copied the image using dd to an external USB disk .
#4 2021-10-17 12:10:39
hevidevi
EFI directory at the root of your HDD  or the USB?
#5 2021-10-17 14:53:47
Maybe this thread gives some hints: https://dev1galaxy.org/viewtopic.php?id=4496
