#1 2021-10-15 01:36:08
erdos
[SOLVED] Apt-get update error during Chimaera upgrade
hi, i'm trying to upgrade to Chimaera from beowulf and encountered the following during apt update:
root@htpc-devuan:/home/erdos/Downloads# apt-get update
Get:1 [url]http://dl.google.com/linux/earth/deb[/url] stable InRelease [1,807 B]
Get:2 [url]https://repo.skype.com/deb[/url] stable InRelease [4,502 B]
Err:1 [url]http://dl.google.com/linux/earth/deb[/url] stable InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 78BD65473CB3BD13
Get:3 [url]https://repo.skype.com/deb[/url] stable/main amd64 Packages [2,256 B]
Get:4 [url]http://deb.devuan.org/merged[/url] chimaera InRelease [33.8 kB]
Get:5 [url]http://deb.devuan.org/merged[/url] chimaera-updates InRelease [26.4 kB]
Get:6 [url]http://deb.devuan.org/merged[/url] chimaera-security InRelease [21.3 kB]
Get:7 [url]http://deb.devuan.org/merged[/url] chimaera/main i386 Packages [8,247 kB]
Get:8 [url]http://deb.devuan.org/merged[/url] chimaera/main amd64 Packages [8,309 kB]
Get:9 [url]http://deb.devuan.org/merged[/url] chimaera/main Translation-en [6,482 kB]
Get:10 [url]http://deb.devuan.org/merged[/url] chimaera-updates/main Translation-en [2,108 B]
Get:11 [url]http://deb.devuan.org/merged[/url] chimaera-security/main i386 Packages [48.0 kB]
Get:12 [url]http://deb.devuan.org/merged[/url] chimaera-security/main amd64 Packages [48.0 kB]
W: GPG error: [url]http://dl.google.com/linux/earth/deb[/url] stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 78BD65473CB3BD13
E: The repository 'http://dl.google.com/linux/earth/deb stable InRelease' is not signed.
i believe i installed zoom and google-earth through .deb package.  is this a concern for continuing upgrade to chimaera?
#2 2021-10-15 02:05:20
Re: [SOLVED] Apt-get update error during Chimaera upgrade
Hi, I don't think it is a concern for updating/upgrading chimaera. Your Earth package may survive intact.
#3 2021-10-15 16:21:40
The recommendation is to exclude all foreign sources from the upgrade. In your case Earth and Skype and maybe Zoom.
Once the upgrade is done you may take care for the other stuff one by one.
#4 2021-10-15 23:56:58
erdos
I encountered additional error while performing 'apt-get dist-upgrade'
Setting up linux-headers-5.10.0-9-amd64 (5.10.70-1) ...
/etc/kernel/header_postinst.d/dkms:
dkms: running auto installation service for kernel 5.10.0-9-amd64:Error! Could not locate dkms.conf file.
File: /var/lib/dkms/nvidia/340.108/source/dkms.conf does not exist.
 failed!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 4
Failed to process /etc/kernel/header_postinst.d at /var/lib/dpkg/info/linux-headers-5.10.0-9-amd64.postinst line 11.
dpkg: error processing package linux-headers-5.10.0-9-amd64 (--configure):
 installed linux-headers-5.10.0-9-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-amd64:
 linux-headers-amd64 depends on linux-headers-5.10.0-9-amd64 (= 5.10.70-1); however:
  Package linux-headers-5.10.0-9-amd64 is not configured yet.
dpkg: error processing package linux-headers-amd64 (--configure):
Setting up libgc1:amd64 (1:8.0.4-3) ...
Setting up linux-image-5.10.0-9-amd64 (5.10.70-1) ...
/etc/kernel/postinst.d/dkms:
 failed!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 4
dpkg: error processing package linux-image-5.10.0-9-amd64 (--configure):
 installed linux-image-5.10.0-9-amd64 package post-installation script subprocess returned error exit status 1
Setting up guile-2.2-libs:amd64 (2.2.7+1-6) ...
dpkg: dependency problems prevent configuration of linux-image-amd64:
 linux-image-amd64 depends on linux-image-5.10.0-9-amd64 (= 5.10.70-1); however:
  Package linux-image-5.10.0-9-amd64 is not configured yet.
dpkg: error processing package linux-image-amd64 (--configure):
Processing triggers for libc-bin (2.31-13+deb11u2) ...
 linux-headers-amd64
 linux-image-amd64
I have proprietary nvidia driver installed before upgrade.
any idea how to proceed?
#5 2021-10-16 02:16:31
linux-image-amd64 is a "Task" package, enables updates for your amd64 kernel.
What you do need is Guile, dkms, linux-headers and linux-headers-common to suit your kernel version, linux-image-5.10.0-9-amd64 (5.10.70-1) installed to get your nvidia drivers/modules installed and running.
#6 2021-10-16 02:53:46
erdos
thanks for the reply!
I try to install 'Guile-3.0', but it seems to indicating that linux-image-5.10.0-9-amd64 isn't properly installed/configured.  i can boot into 4.19 kernel for now but 'apt-get dist-upgrade' results the same error.   trying to remove 'nvidia-persistenced' package also results the same error.
erdos@htpc-devuan:~$ sudo apt-get install guile-3.0
  ant-contrib apt-transport-https bsdmainutils cinnabar-icon-theme
  clearlooks-phenix-cinnabar-theme cpp-8 enchant fonts-arphic-bsmi00lp
  fonts-arphic-gbsn00lp fonts-linuxlibertine fonts-noto-extra
  fonts-roboto-slab fonts-sil-gentium fonts-sil-gentium-basic geoip-database
  gtk2-engines-xfce hp-ppd irqbalance libasan5 libasync-mergepoint-perl
  libbind9-161 libboost-atomic1.67.0 libboost-chrono1.67.0
  libboost-date-time1.67.0 libboost-filesystem1.67.0 libboost-iostreams1.67.0
  libboost-locale1.67.0 libboost-regex1.67.0 libboost-system1.67.0
  libboost-thread1.67.0 libbrlapi0.6 libbsh-java libcdio18 libcec4
  libcgi-fast-perl libcgi-pm-perl libclass-accessor-perl libcodec2-0.8.1
  libcroco3 libcwidget3v5 libdc1394-22 libdigest-bubblebabble-perl
  libdns-export1104 libdns1104 libdns1110 libdouble-conversion1 libdvdread4
  libemail-valid-perl libenchant1c2a libept1.5.0 libevent-2.1-6
  libevent-core-2.1-6 libevent-pthreads-2.1-6 libexiv2-14 libfcgi-bin
  libfcgi-perl libfcgi0ldbl libfluidsynth1 libfuture-perl libgail-3-0
  libgcc1:i386 libgeoip1 libgspell-1-1 libgssdp-1.0-3 libgupnp-1.0-4
  libhdf5-103 libhdf5-fortran-102 libhdf5-hl-100 libhdf5-hl-fortran-100
  libicu63 libigdgmm5 libilmbase23 libio-async-perl libio-pty-perl
  libipc-run-perl libisc-export1100 libisc1100 libisc1105 libisccc161
  libisccfg163 libisl19 libjim0.77 libjs-modernizr libjson-c3 libjsoncpp1
  libjte1 libkyotocabinet16v5 libllvm7 liblouis17 liblouisutdml8 liblua5.3-0
  liblwres161 libm17n-0 libmetrics-any-perl libmpdec2 libmypaint-1.3-0
  libmysofa0 libnet-dns-perl libnet-dns-sec-perl libnet-ip-perl libnfs12
  libnftables0 libopenblas-base libopenexr23 liborcus-0.14-0 libotf0
  libpango-perl libparse-debianchangelog-perl libperl4-corelibs-perl
  libperl5.28 libpgm-5.2-0 libpoppler82 libprocps7 libpython2-stdlib
  libpython2.7 libpython3.7 libpython3.7-minimal libpython3.7-stdlib libqhull7
  libqpdf21 libqscintilla2-qt5-13 libqt5concurrent5 libqt5opengl5 libraw19
  libreoffice libreoffice-avmedia-backend-gstreamer libreoffice-librelogo
  libreoffice-nlpsolver libreoffice-script-provider-bsh
  libreoffice-script-provider-js libreoffice-script-provider-python
  libreoffice-wiki-publisher libsane libsdl1.2debian libsereal-perl
  libsisu-guice-java libsisu-ioc-java libsnmp30 libstruct-dumb-perl
  libtest-fatal-perl libtest-metrics-any-perl libtest-refcount-perl
  libtext-levenshtein-perl libu2f-udev libunique-1.0-0 libusbmuxd4 libvpx5
  libwnck-common libwnck22 libwxgtk3.0-0v5 libx264-155 libx265-165
  libxcb-util0 libxml-simple-perl linux-headers-4.19.0-9-common
  linux-image-4.9.0-12-amd64 linux-kbuild-4.19 m17n-db perl-modules-5.28
  printer-driver-hpijs python-pkg-resources python2 python2-minimal
  python3-gst-1.0 python3.7-minimal runit-helper xfce4-notes
  guile-3.0-libs
Suggested packages:
  guile-3.0-doc
  guile-3.0 guile-3.0-libs
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 6,429 kB of archives.
After this operation, 53.3 MB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged chimaera/main amd64 guile-3.0-libs amd64 3.0.5-4 [6,406 kB]
Get:2 http://deb.devuan.org/merged chimaera/main amd64 guile-3.0 amd64 3.0.5-4 [23.1 kB]
Fetched 6,429 kB in 4s (1,573 kB/s)
Selecting previously unselected package guile-3.0-libs:amd64.
(Reading database ... 215844 files and directories currently installed.)
Preparing to unpack .../guile-3.0-libs_3.0.5-4_amd64.deb ...
Unpacking guile-3.0-libs:amd64 (3.0.5-4) ...
Selecting previously unselected package guile-3.0.
Preparing to unpack .../guile-3.0_3.0.5-4_amd64.deb ...
Unpacking guile-3.0 (3.0.5-4) ...
 failed!
Setting up guile-3.0-libs:amd64 (3.0.5-4) ...
 failed!
Setting up guile-3.0 (3.0.5-4) ...
update-alternatives: using /usr/lib/x86_64-linux-gnu/guile/3.0/bin/guile to provide /usr/bin/guile (guile) in auto mode
Processing triggers for man-db (2.9.4-2) ...
 linux-headers-amd64
 linux-image-amd64
erdos@htpc-devuan:~$ sudo apt-get remove nvidia-persistenced
[sudo] password for erdos:
Package 'nvidia-persistenced' is not installed, so not removed
  ant-contrib apt-transport-https bsdmainutils cinnabar-icon-theme clearlooks-phenix-cinnabar-theme cpp-8 enchant fonts-arphic-bsmi00lp fonts-arphic-gbsn00lp fonts-linuxlibertine
  fonts-noto-extra fonts-roboto-slab fonts-sil-gentium fonts-sil-gentium-basic geoip-database gtk2-engines-xfce hp-ppd irqbalance libasan5 libasync-mergepoint-perl libbind9-161
  libboost-atomic1.67.0 libboost-chrono1.67.0 libboost-date-time1.67.0 libboost-filesystem1.67.0 libboost-iostreams1.67.0 libboost-locale1.67.0 libboost-regex1.67.0 libboost-system1.67.0
  libboost-thread1.67.0 libbrlapi0.6 libbsh-java libcdio18 libcec4 libcgi-fast-perl libcgi-pm-perl libclass-accessor-perl libcodec2-0.8.1 libcroco3 libcwidget3v5 libdc1394-22
  libdigest-bubblebabble-perl libdns-export1104 libdns1104 libdns1110 libdouble-conversion1 libdvdread4 libemail-valid-perl libenchant1c2a libept1.5.0 libevent-2.1-6 libevent-core-2.1-6
  libevent-pthreads-2.1-6 libexiv2-14 libfcgi-bin libfcgi-perl libfcgi0ldbl libfluidsynth1 libfuture-perl libgail-3-0 libgcc1:i386 libgeoip1 libgspell-1-1 libgssdp-1.0-3 libgupnp-1.0-4
  libhdf5-103 libhdf5-fortran-102 libhdf5-hl-100 libhdf5-hl-fortran-100 libicu63 libigdgmm5 libilmbase23 libio-async-perl libio-pty-perl libipc-run-perl libisc-export1100 libisc1100
  libisc1105 libisccc161 libisccfg163 libisl19 libjim0.77 libjs-modernizr libjson-c3 libjsoncpp1 libjte1 libkyotocabinet16v5 libllvm7 liblouis17 liblouisutdml8 liblua5.3-0 liblwres161
  libm17n-0 libmetrics-any-perl libmpdec2 libmypaint-1.3-0 libmysofa0 libnet-dns-perl libnet-dns-sec-perl libnet-ip-perl libnfs12 libnftables0 libopenblas-base libopenexr23 liborcus-0.14-0
  libotf0 libpango-perl libparse-debianchangelog-perl libperl4-corelibs-perl libperl5.28 libpgm-5.2-0 libpoppler82 libprocps7 libpython2-stdlib libpython2.7 libpython3.7
  libpython3.7-minimal libpython3.7-stdlib libqhull7 libqpdf21 libqscintilla2-qt5-13 libqt5concurrent5 libqt5opengl5 libraw19 libreoffice libreoffice-avmedia-backend-gstreamer
  libreoffice-librelogo libreoffice-nlpsolver libreoffice-script-provider-bsh libreoffice-script-provider-js libreoffice-script-provider-python libreoffice-wiki-publisher libsane
  libsdl1.2debian libsereal-perl libsisu-guice-java libsisu-ioc-java libsnmp30 libstruct-dumb-perl libtest-fatal-perl libtest-metrics-any-perl libtest-refcount-perl
  libtext-levenshtein-perl libu2f-udev libunique-1.0-0 libusbmuxd4 libvpx5 libwnck-common libwnck22 libwxgtk3.0-0v5 libx264-155 libx265-165 libxcb-util0 libxml-simple-perl
  linux-headers-4.19.0-9-common linux-image-4.9.0-12-amd64 linux-kbuild-4.19 m17n-db perl-modules-5.28 printer-driver-hpijs python-pkg-resources python2 python2-minimal python3-gst-1.0
After this operation, 0 B of additional disk space will be used.
 failed!
 failed!
 linux-headers-amd64
 linux-image-amd64
#7 2021-10-16 09:50:00
Debuser2018
Try as root or sudo:
apt install -f
and dpkg --configure -a
and if the problem is not resolved, try removing the kernel packages and install nvidia dependencies and later install  kernel.
apt purge linux-image-5.10.0-9-amd64
#8 2021-10-16 13:54:51
erdos
apt install -f
tried both and failed.  it seems to be a dependency hell now.
root@htpc-devuan:/home/erdos# apt install -f
Use 'apt autoremove' to remove them.
 failed!
ver:
 failed!
 linux-headers-amd64
 linux-image-amd64
root@htpc-devuan:/home/erdos# dpkg --configure -a
dpkg: warning: 'ldconfig' not found in PATH or not executable
dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
dpkg: error: 2 expected programs not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
root@htpc-devuan:/home/erdos# apt purge linux-image-5.10.0-9-amd64
  linux-image-5.10.0-9-amd64* linux-image-amd64*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 302 MB disk space will be freed.
(Reading database ... 216585 files and directories currently installed.)
Removing linux-image-amd64 (5.10.70-1) ...
Removing linux-image-5.10.0-9-amd64 (5.10.70-1) ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-4.9.0-12-amd64
I: /initrd.img.old is now a symlink to boot/initrd.img-4.9.0-12-amd64
I: /vmlinuz is now a symlink to boot/vmlinuz-4.19.0-9-amd64
I: /initrd.img is now a symlink to boot/initrd.img-4.19.0-9-amd64
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-5.10.0-9-amd64
/etc/kernel/postrm.d/zz-update-grub:
Generating grub configuration file ...
Found theme: /usr/share/desktop-base/grub-themes/desktop-grub-theme/theme.txt
Found linux image: /boot/vmlinuz-4.19.0-9-amd64
Found initrd image: /boot/initrd.img-4.19.0-9-amd64
Found linux image: /boot/vmlinuz-4.9.0-12-amd64
Found initrd image: /boot/initrd.img-4.9.0-12-amd64
done
 failed!
ver:
 linux-headers-amd64
#9 2021-10-16 14:02:36
erdos
I poke around for the 'missing' dkms.conf file, it's there but in a different directory than devuan expected.
erdos@htpc-devuan:~$ ls -l /var/lib/dkms/nvidia/340.108/
total 4
drwxr-xr-x 2 root root 4096 Mar  7  2020 build
lrwxrwxrwx 1 root root   23 Mar  7  2020 source -> /usr/src/nvidia-340.108
erdos@htpc-devuan:~$ ls -l /usr/src/nvidia-legacy-340xx-340.108/dkms*
-rw-r--r-- 1 root root 861 Feb  2  2020 /usr/src/nvidia-legacy-340xx-340.108/dkms.conf
#10 2021-10-16 15:46:38
Debuser2018
Remove all the 5.x kernels and kernel headers and retry.
apt purge linux-headers-5.10.0-9-amd64 linux-headers-amd64
#11 2021-10-16 16:06:16
erdos
both
apt install -f
are success, but dpkg --configure -a still ends with error.
root@htpc-devuan:/home/erdos# apt purge linux-headers-5.10.0-9-amd64 linux-headers-amd64
  gtk2-engines-xfce hp-ppd libasan5 libasync-mergepoint-perl libbind9-161
  libboost-regex1.67.0 libboost-system1.67.0 libboost-thread1.67.0
  libept1.5.0 libevent-2.1-6 libevent-core-2.1-6 libevent-pthreads-2.1-6
  libgssdp-1.0-3 libgupnp-1.0-4 libhdf5-103 libhdf5-fortran-102 libhdf5-hl-100
  libio-pty-perl libipc-run-perl libisc-export1100 libisc1100 libisc1105
  liblua5.3-0 liblwres161 libm17n-0 libmetrics-any-perl libmpdec2
  liborcus-0.14-0 libotf0 libpango-perl libparse-debianchangelog-perl
  libpython2-stdlib libpython2.7 libpython3.7 libpython3.7-minimal
  libxcb-util0 libxml-simple-perl linux-compiler-gcc-10-x86
  linux-headers-4.19.0-9-common linux-headers-5.10.0-9-common
  linux-kbuild-4.19 linux-kbuild-5.10 m17n-db perl-modules-5.28
  python3-gst-1.0 python3.7-minimal xfce4-notes
  linux-headers-5.10.0-9-amd64* linux-headers-amd64*
2 not fully installed or removed.
After this operation, 5,548 kB disk space will be freed.
(Reading database ... 211815 files and directories currently installed.)
Removing linux-headers-amd64 (5.10.70-1) ...
Removing linux-headers-5.10.0-9-amd64 (5.10.70-1) ...
dpkg: warning: while removing linux-headers-5.10.0-9-amd64, directory '/lib/modu
les/5.10.0-9-amd64' not empty so not removed
(Reading database ... 202885 files and directories currently installed.)
Purging configuration files for linux-headers-amd64 (5.10.70-1) ...
dpkg: warning: while removing linux-headers-amd64, directory '/usr/share/doc/lin
ux-headers-amd64' not empty so not removed
root@htpc-devuan:/home/erdos# y
bash: y: command not found
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
(Reading database ... 202884 files and directories currently installed.)
Purging configuration files for linux-image-5.10.0-9-amd64 (5.10.70-1) ...
#12 2021-10-16 16:18:24
Debuser2018
both
apt install -f
As you see dkms has compiled some modules in the library. Inspect & Remove these directories ('/usr/share/doc/lin
ux-headers-amd64,/lib/modules/5.10.0-9-amd64)  & retry.
rm /usr/share/doc/linux-headers-amd64 && rm /lib/modules/5.10.0-9-amd64
dpkg --configure -a && sync
As regarding the dpkg warnings about missing PATH variables, you may look into: https://unix.stackexchange.com/question … h-variable
#13 2021-10-16 16:26:29
Debuser2018
I assume you're using amd64 (64-bit intels or amd processor). Make sure Google repositories look like this in /etc/apt/sources.list or inside /etc/apt/sources.list.d/ :
deb [arch=amd64] http://dl.google.com/linux/earth/deb/ stable main
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
Add missing GPG key as root:
sudo -i
Then,
wget -q -O - https://dl.google.com/linux/linux_signing_key.pub | apt-key add -
apt update && apt upgrade
#14 2021-10-16 16:33:50
Debuser2018
This is a sample Chimaera /etc/apt/sources.list:
# Devuan chimaera
deb http://deb.devuan.org/merged chimaera main contrib non-free
#deb-src http://deb.devuan.org/merged chimaera main contrib non-free
deb http://deb.devuan.org/merged chimaera-security main contrib non-free
# deb-src http://deb.devuan.org/merged chimaera-security main
# chimaera-updates, previously known as 'volatile'
# A network mirror was not selected during install.  The following entries
# are provided as examples, but you should amend them as appropriate
# for your mirror of choice.
deb http://deb.devuan.org/merged chimaera-updates main contrib non-free
# deb-src http://deb.devuan.org/merged chimaera-updates main
deb http://deb.devuan.org/merged chimaera-backports main contrib non-free
# deb-src http://deb.devuan.org/merged chimaera-backports main
deb http://deb.devuan.org/devuan chimaera-proposed main contrib non-free
# Google Chrome & earth pro
# Ubuntuzilla for Firefox browser
# deb http://downloads.sourceforge.net/projec … ozilla/apt all main
deb https://altushost-swe.dl.sourceforge.ne … ozilla/apt all main
#15 2021-10-17 02:54:10
erdos
i was able to run above commands, removed /usr/share/doc/linux-headers-amd64,  /lib/modules/5.10.0-9-amd64 doesn't exist though.  'dpkg' runs ok too after modify path.
but trying to reinstall 5.10 kernel/headers still results the same error - complaining it couldn't find dkms.conf
apt install linux-headers-5.10.0-9-amd64 linux-headers-amd64
root@htpc-devuan:/home/erdos# export PATH="$PATH:/sbin"
root@htpc-devuan:/home/erdos# apt install linux-headers-5.10.0-9-amd64 linux-headers-amd64
  glx-alternative-mesa libbsd0:i386 libmd0:i386 libx11-6:i386 libxau6:i386 libxcb1:i386 libxdmcp6:i386 libxext6:i386
  update-glx
Need to get 0 B/902 kB of archives.
After this operation, 5,548 kB of additional disk space will be used.
Selecting previously unselected package linux-headers-5.10.0-9-amd64.
(Reading database ... 182681 files and directories currently installed.)
Preparing to unpack .../linux-headers-5.10.0-9-amd64_5.10.70-1_amd64.deb ...
Unpacking linux-headers-5.10.0-9-amd64 (5.10.70-1) ...
Selecting previously unselected package linux-headers-amd64.
Preparing to unpack .../linux-headers-amd64_5.10.70-1_amd64.deb ...
Unpacking linux-headers-amd64 (5.10.70-1) ...
 failed!
 linux-headers-amd64
i purged all 'nvidia' in the system, and tried again, still no success.
# apt-get  remove --purge '^nvidia-.*'
It seems that repository is messed up now, i couldn't find any 'nvidia' driver include 'nvidia-persistenced',  using synaptics display ed 'xserver-xorg-video-nvidia-legacy-340xx' but shows:
Package xserver-xorg-video-nvidia-legacy-340xx has no available version, but exists in the database.
This typically means that the package was mentioned in a dependency and never uploaded, has been obsoleted or is not available with the contents of sources.list"
#16 2021-10-17 05:16:39
Debuser2018
A simple Google search gave this result:
https://askubuntu.com/questions/227258/ … -conf-file
I think there is no dependency hell, rather some missing or conflicting modules or conf files that needs to be sorted. It is achievable.
#17 2021-10-17 15:38:20
erdos
thanks!
erdos@htpc-devuan:~$ for i in /var/lib/dkms/*/[^k]*/source; do [ -e "$i" ] || echo "$i";done
removed 'nvidia' directory, and reinstalled header/kernel for 5.10, ok
rm -r /var/lib/dkms/nvidia
apt-get update && apt-get upgrade
apt-get autoremove --purge
apt install linux-image-5.10.0-9-amd64
I updated /etc/apt/sources.list to include 'no-free' and update repository list:
however, it seems that i could no longer install nvidia driver for my graphics card (GeForce 9300 GE), i.e. nvidia-legacy-340xx-driver
erdos@htpc-devuan:~$ sudo apt-get install nvidia-legacy-340xx-driver
Package nvidia-legacy-340xx-driver is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'nvidia-legacy-340xx-driver' has no installation candidate
this driver is no longer available in chimaera
https://pkginfo.devuan.org/cgi-bin/poli … r&x=submit
#18 2021-10-18 02:51:56
erdos
solution has been given here https://dev1galaxy.org/viewtopic.php?id=4585
