#1 2021-09-08 09:30:02
pit
Can't overcome 'grub minimal edit shell' problem
Hello everybody,
some time ago (several months I suppose), after safe-upgrade my Devuan Beowulf on P50 stopped booting, after some those days and recent activities I got grub booting but every time to 'minimal editing' mode.
Tricks with setting root/prefix/normal mod leads to normal boot process, however subsequent after-boot 'grub-install/update-grub' do not cause any changes and minimal-edit mode is still auto started with no menu present, not sure how to debug, could that be any grub configuration issue?
Thanks,
#2 2021-09-08 17:46:38
Re: Can't overcome 'grub minimal edit shell' problem
Maybe try (re)installing grub via a 'live' USB drive session(?).
#3 2021-09-08 18:11:07
snork
If this is what is going on then you might be able to solve it with
apt-get purge grub-efi-amd64-signed
#4 2021-09-09 08:49:49
pit
and that worked out! big thanks!
#5 2021-09-09 08:55:05
Alternatively rename /boot/efi/EFI/devuan/ to /boot/efi/EFI/debian/ and keep the signed GRUB package so that Secure Boot will actually work.
See also https://bugs.debian.org/cgi-bin/bugrepo … bug=925309
EDIT: corrected paths.
#6 2021-09-09 09:14:30
pit
I do not use Secure Boot, but thanks anyway, will keep in mind in case I'll need it
