#1 2021-09-03 16:27:27
Monti
[SOLVED] SDDM not starting up after fresh Beowulf installation
I have just installed Beowulf with KDE and SDDM as display manager.
My problem is that SDDM login screen is not starting up, so as you understand I have to use the "startx /usr/bin/startkde" command to get into KDE desktop.
Could someone please advice?
Thanks,
Monti
#2 2021-09-03 21:30:10
Re: [SOLVED] SDDM not starting up after fresh Beowulf installation
Check the logs.
#3 2021-09-04 10:23:22
PedroReina
From a root console service sddm restart could sent some error messages.
#4 2021-09-04 22:50:57
Monti
Thank you guys for your replies.
Did not get any error messages, but the issue was solved after installing the firmware-amd-graphics package. So the problem was that SDDM did not start when necessary ATI/AMD firmware was not installed. After "firmware-amd-graphics" was installed SDDM started automatically with no other configurations.
Monti
#5 2021-09-05 08:47:36
PedroReina
Long time ago I explained in a course about Debian how install X server and probing it working using the order X before installing any graphics login program. The course was very slow paced; nowadays we all can work much faster because everything works much better than 20 years ago, but knowing the basics is always useful.
#6 2021-09-06 14:19:29
Monti
Thank you Pedro for your additional input. Do you know about a good tutorial which go into what you taught?
#7 2021-09-07 09:14:25
PedroReina
My own script for that course is very dated (Debian 3) and in Spanish, but it is here: IntranetEducativa.pdf
I'm not aware of a similar slow paced tutorial, but may be because I no longer teach IT. Maybe projects as Linux from Scratch can be useful to you; I would give it a try, I learn a lot back in the day with it.
