#1 2021-08-08 17:59:45
recklessswing
Is it possible to use pipewire in devuan 4?
In debian wiki, there are some systemd commands. Couldn't find sysvinit equivalent of them. What to do?
#2 2021-08-08 20:31:28
larsH
Re: Is it possible to use pipewire in devuan 4?
Hi
It is currently only possible to start pipewire manually in every session. Their scripts is currently depending on systemd. So I think a no go currently on devuan. And the main developer is the same who invented the pulseaudio crap. So I am suspicious to pipewire. It might develop a new systemd on the multimedia front.
You might have a look on the situation on gentoo: https://wiki.gentoo.org/wiki/PipeWire
Have a nice day
#3 2021-08-08 21:05:14
Alpine uses a file at /etc/xdg/autostart/ to run PipeWire automatically for most desktops:
https://git.alpinelinux.org/aports/tree … re.desktop
No, the PipeWire creator & main developer is Win Taymans. EDIT: although they do work for Red Hat :-)
#4 2021-08-21 08:48:35
EDX-0
and that is a non issue, since i use a window manager i already start pulse on .xprofile
! pidof pulseaudio >/dev/null &&
setsid -f pulseaudio --start >/dev/null 2>&1 &
i'm waiting on the pipewire documentation so that i can either add pipewire support to the volume module i have on my bar or write a new one targeting pipewire
as despite the fact that is a redhat project it seems to be better than pulse with the promise of reduced latency and jack integration it means no longer there's a need for messing with the awful pulse loopbacks and instead audiostreams can be managed on a jack patchbay
#5 2021-08-23 07:57:31
larsH
Hi
Yeah, it looks like a better solution than pulseaudio. But again is Redhat making a big monolithic system. Video and audio in one solution. To me it does not look as the best solution. But lets see how things goes when pipewire matures.
Have a nice day
#6 2021-08-25 23:54:37
EDX-0
the video thing is only necesary for wayland since wayland doesn't allow desktop capture like x11 does
#7 2021-10-15 05:00:23
Debuser2018
Is it possible to use pipewire instead of pulseaudio in Chimaera?
#8 2021-10-15 11:55:52
Ogis1975
Check this https://wiki.debian.org/PipeWire
In short-This is not a supported scenario for Debian 11, and is considered experimental. It may break certain applications, lack certain functionality, or not work at all.
            ----+- Peter Kropotkin -+----
#9 2021-10-16 16:35:27
Debuser2018
@Ogis1975: Thanks for the info. I will wait, rather.
