#1 2021-08-08 13:18:59
steelpillow
[SOLVED] http vs https
Upgrading from ascii to beowulf and I notice the urls for the repos are still given using http rather than https. They are working OK, but would https work equally well - and if not, why not?
— Cheers
#2 2021-08-08 14:00:44
Re: [SOLVED] http vs https
There are https mirrors available, refer to https://www.devuan.org/get-devuan.
Nevertheless, the sources.list should look like described in https://www.devuan.org/os/packages.
No matter if you use http or https, the checksums of the individual packages ensure that they are safe.
#3 2021-08-08 14:58:28
steelpillow
Thanks.
— Cheers
