#1 2021-07-07 00:09:01
[SOLVED] Ownership/permisisons of /home/user/mbox
Just came across this when I was doing some maintenance in a Devuan ascii 4.19.0-17-686-pae installed on an Asus 1000HE 2Gb.
groucho@eee-dev3:~$ ls -l /home/groucho/mbox
-rw------- 1 root root 5691 May 30  2019 /home/groucho/mbox
groucho@eee-dev3:~$
I cannot access my own mbox.  8^'
Any idea as to how this could have happened?
I belong to the groups I should belong to.
groucho@eee-dev3:~$ groups
groucho adm disk mail dialout voice cdrom floppy tape sudo audio dip backup video plugdev users crontab netdev bluetooth Debian-exim pulse pulse-access
groucho@eee-dev3:~$
How is it that I have to chown my own user mbox?
Thanks in advance,
#2 2021-07-07 11:34:31
Re: [SOLVED] Ownership/permisisons of /home/user/mbox
I was not able to find out why this happened, which would have been nice.
But I was able to fix it without using chown.
Turns out that, for whatever reason, there were two mailboxes in /home/user//.mbox and /mbox, only the first one available to my user.
But when I logged in and checked my mail, mail checked the mailbox that should have been available to my user. ie: /mbox which belonged to root.
So I just did # rm .mbox and # rm mbox, rebooted, checked my user mail and now all is as it should be.
#3 2021-07-07 17:05:36
Check what root's home directory is (ie it's not /home/groucho). Then look in it to see what it has for it's mbox.
Did you ever switch to root via su without a -, then run mail as root? Or do something else that could make root think it's home dir is /home/groucho ?
Chris
#4 2021-07-07 19:27:00
chris2be8 wrote:
Check what root's home directory is ...
groucho@eee-dev3:/var/mail$ ls -l
total 0
-rw-rw---- 1 groucho mail 0 Jul  7 16:14 groucho
-rw------- 1 root    mail 0 Jul  6 22:18 root
chris2be8 wrote:
... ever switch to root via su without a -, then run mail as root?
Ahhh ...
That could have been the culprit. ie: me.
I have that annoyance fixed in my box but not yet in the 1000HE.
Fixed now. 8^)
Thanks for the heads up.
