#1 2021-06-29 16:09:43
Copper36
Minimal KDE install in Beowulf
I'd like to make a fresh install of Beowulf with a KDE desktop on a new box, but I do not need that huge bundle of KDE apps installed by default. As far as I can see, the things has not changed and it's still a PITA to remove them after the full KDE has been installed.
What is the correct way to run a minimal install of KDE desktop? What I have found so far is to run a net install without DE, and after it's done to manually install minimal KDE running
apt -y kde-plasma-desktop plasma-nm
Is this correct? By any chance, is there a minimal KDE-plasma install option in the "regular" installer?
Thank you.
#2 2021-06-29 17:18:59
Re: Minimal KDE install in Beowulf
Copper36 wrote:
Is this correct?
Almost:
# apt install -y kde-plasma-desktop plasma-nm
No but you can add a custom entry to tasksel with this file at /usr/share/tasksel/descs/kde-minimal.desc:
Task: KDE-minimal
Relevance: 2
Parent: desktop
Key:
Packages: list
   kde-plasma-desktop
   plasma-nm
Section: user
Description: Minimal KDE desktop
Not sure if the installer actually uses tasksel but if it does then you could perhaps remaster it with this addition.
EDIT: 3-space tabs ftw.
#3 2021-06-30 15:24:51
dice
this is a fairly decent overview of what you may want in below link.
https://www.pragmaticlinux.com/2020/10/ … 10-buster/
even though it says debian buster it should apply to devuan as well as long as you are aware of the differences in the installers.
#4 2021-07-02 00:46:16
pcalvert
I would use a slightly different approach:
# aptitude install -R kde-plasma-desktop plasma-nm kwin-x11 sddm xserver-xorg 2>&1 | tee KDE-desktop-installation-log.txt
This installs KDE without recommended packages. That's why I save a log of the installation. After the installation, I would open the log file and look to see which recommended packages weren't installed because I may want to install some of them.
Disclaimer: I haven't actually tried this because I don't use KDE anymore. However, this is the general approach I would use to install any desktop environment, and I have used it to install Xfce.
Another one is called Luxxle.
#5 2021-07-04 21:24:10
Copper36
Task: KDE-minimal
Relevance: 2
Parent: desktop
Key:
Packages: list
   kde-plasma-desktop
   plasma-nm
Section: user
Where do I look for this file? I do not see anything like this in the installation image. There is a package called tasksel however... I'm afraid I just do not understand what you mean, sorry.
#6 2021-07-04 21:26:08
Copper36
Thanks!
#7 2021-07-05 16:56:22
It would be created manually. How to add it depends on the installer used and I'm not sure how Devuan's works (sorry). I don't even know if the Devuan installer uses tasksel at any stage.
#8 2021-07-05 19:44:31
Copper36
Well, I followed the method (https://www.pragmaticlinux.com/2020/10/ … 10-buster/) suggested by dice, but as usual, there are problems... Base system installs, installation of basic plasma-nm and KDE is also fine, but after reboot I still face the same tty1.
#9 2021-07-10 20:56:38
Copper36
As far as I can see, running
apt list -a --installed *something*
sddm and xserver are installed, but xinit is not...
The content of  /var/log/boot is:
(Nothing has been logged yet. If you're still seeing this message your current init system might not write bootup messages to the system console at all.)
Sat Jul 10 17:34:14 2021: [....] Activating swap...??7[ ok 8??done.
Sat Jul 10 17:34:14 2021: [....] Checking file systems...fsck from util-linux 2.33.1
Sat Jul 10 17:34:14 2021: fsck.fat 4.1 (2017-01-24)
Sat Jul 10 17:34:14 2021: /dev/nvme0n1p1: 382 files, 41850/125952 clusters
Sat Jul 10 17:34:14 2021: /dev/nvme0n1p6: clean, 20/13189120 files, 1105464/52735744 blocks
Sat Jul 10 17:34:14 2021: ??7[ ok 8??done.
Sat Jul 10 17:34:14 2021: [....] Cleaning up temporary files... /tmp??7[ ok 8??.
Sat Jul 10 17:34:14 2021: [....] Mounting local filesystems...??7[ ok 8??done.
Sat Jul 10 17:34:14 2021: [....] Activating swapfile swap...??7[ ok 8??done.
Sat Jul 10 17:34:14 2021: [....] Cleaning up temporary files...??7[ ok 8??.
Sat Jul 10 17:34:14 2021: [....] Starting: AppArmor[....] $Mounting securityfs on /sys/kernel/security??7[ ok 8??.
Sat Jul 10 17:34:14 2021: [....] Loading AppArmor profiles...??7[ ok 8??done.
Sat Jul 10 17:34:14 2021: ??7[ ok 8??.
Sat Jul 10 17:34:14 2021: [....] Starting Setting kernel variables: sysctl??7[ ok 8??.
Sat Jul 10 17:34:14 2021: [....] Configuring network interfaces...ifup: waiting for lock on /run/network/ifstate.eth0
Sat Jul 10 17:34:20 2021: ifup: interface eth0 already configured
Sat Jul 10 17:34:20 2021: ??7[ ok 8??done.
Sat Jul 10 17:34:20 2021: [....] Cleaning up temporary files...??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Setting up X socket directories... /tmp/.X11-unix /tmp/.ICE-unix??7[ ok 8??.
Sat Jul 10 17:34:20 2021: INIT: Entering runlevel: 2
Sat Jul 10 17:34:20 2021: [info] Using makefile-style concurrent boot in runlevel 2.
Sat Jul 10 17:34:20 2021: [....] Setting up console font and keymap...??7[ ok 8??done.
Sat Jul 10 17:34:20 2021: [....] Starting enhanced syslogd: rsyslogd??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Starting anac(h)ronistic cron: anacron deferred while on battery power??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Starting periodic command scheduler: cron??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Starting system message bus: dbus??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Starting bluetooth: bluetoothd??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Starting session management daemon: elogind??7[ ok 8??.
Sat Jul 10 17:34:20 2021: [....] Starting network connection manager: NetworkManager??7[ ok 8??.
Sat Jul 10 17:34:21 2021: [....] Starting Init script for Simple Desktop Display Manager: sddm??7[ ok 8??.
Could it be due to the lack of the drivers' support for my hardware (it is i5 11th gen with Xe GPU)?
I also did not set a root password during installation.
Thank you.
#10 2021-07-10 22:52:45
Hi, I think Tasksel is the page in the install program that allows us to select what desktop we want installed, like xfce, kde, cinnamon, etc.
If it's not booting to a login gui, have you got elogind installed?
Just my 2c. All the best.
#11 2021-07-10 23:01:14
Copper36
Elogind is installed (automatic).
Thanks!
#12 2021-07-11 09:48:04
11th generation Intel graphics need a newer version of Mesa than is available in beowulf.
#13 2021-07-11 14:02:57
Magnus
You will need at least three packages newer than Beowold to use the 11th generation of Intel processors. In any case, this applies to i7, and I think it also applies to i5.
The packages are:
intel-media-va-driver-non-free for graphics
https://pkginfo.devuan.org/cgi-bin/pack … .1.1+ds1-1
firmware-sof-signed for audio
https://pkginfo.devuan.org/cgi-bin/pack … gned=1.7-1
firmware iwlwifi for wifi
https://pkginfo.devuan.org/cgi-bin/pack … -2~bpo10+1
The easiest way is to add Debian's Experimental to your source list and just run 'aptitude upgrade -t experimental'. That's what I've been running for a few weeks to get the latest KDE and the latest of it all. ;-)
#14 2021-07-11 23:13:39
Copper36
Ah, so it won't work anyway... But just out of curiosity - do you think my problem is due to the old mesa driver or maybe systemd/sysvinit differences? The same approach worked with Buster, however I have no idea on what hardware.
Thank you.
#15 2021-07-12 15:57:46
Copper36
OK guys, thank you very much for all your help and assistance, hope to see you in a few years.
