#1 2021-06-19 15:34:41
[SOLVED] Cleaning up installation
After a good while of using a newer kernel in Beowulf and with no evident issues, I've decided to clean up old stuff.
[root@devuan groucho]# uname -a
Linux devuan 5.10.0-0.bpo.3-amd64 #1 SMP Debian 5.10.13-1~bpo10+1 (2021-02-11) x86_64 GNU/Linux
So I first had a look at what was there:
groucho@devuan:~$ apt list | grep linux-headers | grep installed
linux-headers-4.19.0-17-amd64/stable,now 4.19.194-1 amd64 [installed,automatic]
linux-headers-4.19.0-17-common/stable,stable,now 4.19.194-1 all [installed,automatic]
linux-headers-5.10.0-0.bpo.3-amd64/stable-backports,now 5.10.13-1~bpo10+1 amd64 [installed]
linux-headers-5.10.0-0.bpo.3-common/stable-backports,stable-backports,now 5.10.13-1~bpo10+1 all [installed,automatic]
linux-headers-amd64/stable,now 4.19+105+deb10u12 amd64 [installed]
groucho@devuan:~$
Seeing that 4.19.0-17 was the target for removal, I opened a terminal:
[root@devuan groucho]# apt purge linux-headers-4.19.0-17-amd64
Building dependency tree
  linux-headers-4.19.0-17-common linux-kbuild-4.19
Use 'apt autoremove' to remove them.
  linux-headers-4.19.0-17-amd64* linux-headers-amd64*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 5268 kB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
Is this right?
ie: linux-headers-amd64  -> Linux devuan 5.10.0-0.bpo.3-amd64 does not need it?
#2 2021-06-19 16:04:30
Re: [SOLVED] Cleaning up installation
I'd try apt-get --simulate autoremove first and see what it said it would remove (or apt --simulate autoremove). Then double-check it wasn't saying it would remove anything current.
Chris
#3 2021-06-19 16:43:36
Is this right?
ie: linux-headers-amd64  -> Linux devuan 5.10.0-0.bpo.3-amd64 does no need it?
Yes, that's right. The kernel does not have the headers listed as a dependency. The headers are only needed for building custom kernel modules so most users don't need them.
#4 2021-06-19 19:08:06
chris2be8 wrote:
I'd try apt-get --simulate autoremove ...
That didn't show anything
Yes ...
... kernel does not have the headers listed as a dependency.
... only needed for building custom kernel modules so most users don't need them.
Good to know.
Thanks for the heads up.  8^)
I can now continue with the housekeeping.
#5 2021-06-19 19:16:10
Marjorie
Is this right?
I think you do still need the current kernel headers to recompile the kernel module for NVidia if you are using NVidia's own driver.
#6 2021-06-19 20:49:20
NVIDIA's kernel module would be considered "custom" even if compiled from the Debian package. The kernel ring buffer will have a message about the module tainting the kernel.
#7 2021-06-20 00:43:08
Marjorie wrote:
... still need the current kernel headers to recompile the kernel module for NVidia if you are using NVidia's own driver.
Now that you mention it, my memory's been reactivated.  8^/
I recall that having that package installed was neecessary.
HevyDevy figured out how to install the proprietary drivers some time ago when I was having some problems (persistance package IIRC) and part of the sequence was installing the headers if they were not there.
I am on Beowulf but with a backported kernel so I don't know what applies.
In any case, if I ever have to install the Nvidia stuff again, I'll probably find out.
