Pages: 1
My Devuan box has four SAS drive slots, an on-board USB socket and room to comfortably install an additional two or three 2.5" drives.
I use UUID to keep the installation behaving properly (so to speak) but although this works, drive letters move around between UUIDs if I add a drive.
This affects my conky output by mean of which I monitor drive temperatures.
/dev/sda: +${execi 60 hddtemp /dev/disk/by-uuid/d6841f29-e39b-4c87-9c52-3a9c3bafe2d3 | cut -c 81-84}
/dev/sdb: +${execi 60 hddtemp /dev/disk/by-uuid/49d1369c-ed70-4543-b0ee-ef65327e101b | cut -c 83-86}
/dev/sdc: +${execi 60 hddtemp /dev/disk/by-uuid/bdf33361-5929-433e-ac7f-1a626aa6e844 | cut -c 78-81}
/dev/sdd: +${execi 60 hddtemp /dev/disk/by-uuid/7a33fda5-abda-451b-b6ef-c17553c78810 | cut -c 83-86}
/dev/sde: +${execi 60 hddtemp /dev/disk/by-uuid/ca8dbded-819d-4e2b-b017-0981a75ea718 | cut -c 101-104}
When I added an old SATA drive for testing purposes, drive letters got shuffled down, the new drive became /dev/sda and the one that was /dev/sda became /dev/sdb.
So, while I am still monitoring a specific drive's temperature, I sort of lost as to which drive it is.
It's just a labelling but it is what I use to ID the drives and their temperatures via conky.
Maybe I should skip the /dev/sdx system and just go with something like Drive N?
Comments welcome.
Thanks in advance,
Never tried it myself, but at least in theory you should be able to assign letters to specific UUID's using (e)udev rules.
I think.... ![]()
I have a similar problem with harddrives and conky, but for me it's monitoring disk space.
The last thing I remember changing was installing a test drive of kali to a spare drive,
but repartitioning that hd caused a re-organisation of drive letters.
I formatted all the swap partitions, just to start clean, and reparted sdg for a kali test drive. (nero, new kde next)
I manage to stay on top of it, but it's a bit of a pain...
just now while reading your post I realised the diskspace for / and /home were accounting for sdc, not sda (kali on sdg).
I'll keep tabs on this to see what happens. And I'll post back if I find a solution. I love my conky.
... should be able to assign letters to specific UUID's using (e)udev rules.
I think it may be easier to just assign labels instead of saying /dev/sdx.
eg:
SATA1: +${execi 60 hddtemp /dev/disk/by-uuid/d6841f29-e39b-4c87-9c52-3a9c3bafe2d3 | cut -c 81-86} Thanks for your input.
... for me it's monitoring disk space.
I monitor disk space like this:
DISKS
${hr 2}
/ $alignc ${fs_used /} / ${fs_size /} $alignr ${fs_used_perc /}%
${fs_bar /}
/home $alignc ${fs_used /home} / ${fs_size /home} $alignr ${fs_used_perc /home}%
${fs_bar /home}
/media/backups $alignc ${fs_used /media/backups} / ${fs_size /media/backups} $alignr ${fs_used_perc /media/backups}%
${fs_bar /media/backups}
/var/log $alignc ${fs_used /var/log} / ${fs_size /var/log} $alignr ${fs_used_perc /var/log}%
${fs_bar /var/log}Not my doing but cannot recall the source.
^ This: https://wiki.debian.org/Persistent_disk … e_solution
Doesn't work with systemd-udev but eudev might be more compliant.
Pages: 1
