Pages: 1
Hi
Believe it or not, I disabled my touchpad! Too much messed around with the settings ![]()
It is only deactivated on the user account. If I log in as root it works.
How can I reactivate it for the user? From root or with a code in the comande line?
Thanks for the help!
Login with root I could find a way with navigating with the keyboard. But in my user also the keyboard is not activ :-(
I have to go to applications menu / settings / mouse and touchpad and there make the check on "Enable this service"
But how?
Are you using a particular desktop environment or window manager?. There are a couple of threads in the mailing list dedicated to how to enable/disable the touchpad:
https://lists.dyne.org/lurker/search/20 … ad.es.html
Indeed, Steve Litt shared a script for that:
https://lists.dyne.org/lurker/message/2 … 20.es.html
This could help you.
@aitor
I am using Xfce and fluxbox. But I was just clicking on that option to "turn off the device"! Maybe would be good, if there would come warning? Why I clicked there? Because I tried to speed up my touchpad in order the arrow is moving faster. But the settings have no effect, also not after boot. Also back to default is not activ, just grew. If maybe you know how to do this? I need more speed on moving the arrow, it is to slow for me.
Why would anyone want a touchpad enabled?
I find it annoying, although if you don't use a thinkpad, then it is kind of needed, eh?
That being said, I always have touchpad set to disable as soon as jwm starts, because it is a pain in the ass to have touchpad on when I mostly use trackpoint anyways.
Strangely enough, I had a guide on my bookmarks, but cannot find it now...
If its disabled, I hope you have a mouse until you figure out how to fix it.
If you wish to be humbled, try to exalt yourself long term If you wish to be exalted, try to humble yourself long term
Favourite operating systems: Hyperbola Devuan OpenBSD
Pages: 1
