#1 2021-05-20 10:45:07
bimon
How to activate S6 init together with OpenRC?
Hello,
I use OpenRC with my Devuan installation.
Now I would like to extend it with S6 supervisor.
Please let me know how to activate it?
I have installed following packages and rebooted.
root@chimaera:/usr/share/doc/s6# dpkg -al | grep s6
ii  libfs6:amd64                                                2:1.0.8-1                                                 amd64        X11 Font Services library
ii  libncurses6:amd64                                           6.2+20201114-2                                            amd64        shared libraries for terminal handling
ii  libs6-2.10:amd64                                            2.10.0.2-1                                                amd64        small and secure supervision software suite (shared library)
ii  s6                                                          2.10.0.2-1                                                amd64        small and secure supervision software suite
ii  s6-doc
I still do not see S6 process tree which is present for example in linuxserver.io docker images.
May be docs contain this info, but I would like at least a fast start into beginning of using it and then learn it deeper.
#2 2021-05-20 13:55:48
Geoff 42
Re: How to activate S6 init together with OpenRC?
I have not got round to looking at S6 yet, but don't you just need to insert
supervisor=s6
into the OpenRC service script for a particular service.
https://github.com/OpenRC/openrc/blob/m … 6-guide.md
Geoff
