#1 2021-05-15 12:49:23
alphalpha
Tape drives
So i found this iomega tape 250 drive along with this 3gb ditto tape that belonged to grandpas first pc
and i bought a chinese floppy to usb converter (picture)
the question is, how do i get it to work?
in the repository is a tool that is called mt-st and it looks like it is the right tool for the job
however when i try it, i get this
mt-st rewind
/dev/tape: No such file or directory
lsusb indicates that a new usb device is found, but it does not show as a tape drive
i dont even know if this thing is still working or if i plugged the connector the right way because there is no indication which way it goes
any ideas?
#2 2021-05-15 13:23:16
dice
Re: Tape drives
Maybe try the gnu version? I dont know if there is a difference but when i installed mt-st i get 2 versions, mt-st and mt-gnu ??
https://manpages.debian.org/testing/cpi … .1.en.html
#3 2021-05-15 13:36:04
alphalpha
Re: Tape drives
mt-gnu rewind
mt-gnu: /dev/tape: rmtopen failed: No such file or directory
ls /dev/tape
ls: cannot access '/dev/tape': No such file or director
it does not recognize it as a tape drive
i just noticed there is a jumper on the back that can be set to DS1, DS0 or DSP, it is currently on DSP
edit:
sudo mt-st -f /dev/sdc status
does nothing, at least there is no noise and no output
#4 2021-05-15 13:46:59
dice
Re: Tape drives
does dmesg give any hints  maybe?
unplug and plug in while below command is running in a terminal.
# dmesg -wH
also is there any output when you do
# mt status
i found this with a search which may help...
http://etutorials.org/Linux+systems/how … e+Devices/
#5 2021-05-15 14:01:07
alphalpha
Re: Tape drives
dmesg -wH
[  +0.682265] scsi 6:0:0:0: Direct-Access     TEAC     USB UF000x       0.00 PQ: 0 ANSI: 0 CCS
[  +0.000354] sd 6:0:0:0: Attached scsi generic sg2 type 0
[  +0.191556] sd 6:0:0:0: [sdc] 2880 512-byte logical blocks: (1.47 MB/1.41 MiB)
[  +0.064088] sd 6:0:0:0: [sdc] Write Protect is off
[  +0.000006] sd 6:0:0:0: [sdc] Mode Sense: 00 46 02 00
[  +0.063989] sd 6:0:0:0: [sdc] No Caching mode page found
[  +0.000004] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[  +8.127890] sd 6:0:0:0: [sdc] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  +0.000012] sd 6:0:0:0: [sdc] tag#0 Sense Key : Medium Error [current]
[  +0.000006] sd 6:0:0:0: [sdc] tag#0 Add. Sense: Incompatible medium installed
[  +0.000013] sd 6:0:0:0: [sdc] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 00 00
[  +0.000002] print_req_error: I/O error, dev sdc, sector 0
[  +0.000003] Buffer I/O error on dev sdc, logical block 0, async page read
 mt status
from man mt-gnu:
The device must be either a character special file or a remote tape drive.
/dev/sdc is not character special but block special
#6 2021-05-15 14:07:42
dice
Re: Tape drives
so is this thing attached to a floppy drive?
maybe you need fdutils?
# apt install fdutils
might be problematic due to the usb connection of the tape drives.
Have a read of this here: https://www.linux.org/threads/how-do-i- … ive.33919/
I know yours is not a travan tape drive but could be a similar issue.
#7 2021-05-15 15:49:31
Re: Tape drives
Hello.
alphalpha wrote:
... iomega tape 250 drive along with this 3gb ditto tape ...
Nice find.  8^)
alphalpha wrote:
... how do i get it to work?
The key to this may be here:
Wiki wrote:
Technical aspects
Ditto internal drives were connected through the floppy drive channel and used MFM encoding to store data (the same method as on older floppy drives). An ISA accelerator card called the Ditto Dash, providing higher speed than a stock floppy controller, was also available.
Check that the USB Floppy adapter is correctly inserted.
It should (?) have a key (like the IDE cables did) or some indication in the adapter's manual/instruction sheet.
See:
https://en.wikipedia.org/wiki/Ditto_(drive)
https://www.manualslib.com/products/Iom … 35190.html   <---- | x |
https://johnvidler.co.uk/linux-journal/LJ/022/1215.html
http://pong.tamu.edu/~baum/linux/LDP/HO … TO-28.html
Edit:
https://tldp.org/HOWTO/pdf/ZIP-Drive.pdf
#8 2021-05-15 21:19:44
alphalpha
Re: Tape drives
i used this adapter --> link
there is no indicator, but im sure i have it correctly now
the usb device would show up either way but only when it is right side up, it shows sdc in lsblk
as i said earlier, mt-gnu expects a character special file or a remote tape drive
can i create that file with mknod or something?
i tried
mknod tape c 8 32
where 8 and 32 are MAJ and MIN from /dev/sdc
but no success
#9 2021-05-15 22:17:20
Re: Tape drives
i tried
mknod tape c 8 32
but no success
Try with the b flag instead of c, for block-oriented devices:
mknod /dev/{filename} b MAJOR MINOR
#10 2021-05-20 15:01:27
alphalpha
Re: Tape drives
mknod was the wrong approach,
maybe eudev can do something
#11 2021-05-20 19:30:00
Re: Tape drives
Did you try making /dev/tape a link to /dev/sdc? (though it might well need some API adapter between)
#12 2021-05-21 17:02:15
alphalpha
Re: Tape drives
you mean just do
sudo ln /dev/sdc /dev/tape
sudo mt-gnu status
mt-gnu: /dev/tape is not a character special file
#13 2021-05-22 00:38:47
Re: Tape drives
Based on a shallow look-around, it would seem you'll need to get the "st" module loaded.
Perhaps a plain
# modprobe st
is sufficient, or maybe it needs some more intricate incantation.
(Possibly it needs a tape loaded at the time)
Look up Documentation/scsi/st.rst in the kernel source for details of that module.
#14 2021-05-22 08:29:46
Re: Tape drives
alphalpha wrote:
you mean just do
sudo mt-gnu status
Did you try exporting the TAPE variable:
export TAPE=/dev/stX
mt-gnu might use the value of this variable as the default device, so that you'll be able to by-pass the /dev/tape symlink.
Ralph is right, tape devices should be named /dev/stX.
#15 2021-05-22 10:48:23
dice
Re: Tape drives
^ that is what i was thinking needed to happen when i looked at the  mt-gnu manpage, i have hadnt much to do with mknod, i suppose it is similiar to makedev.
#16 2021-05-22 11:57:25
Re: Tape drives
Are you sure it's a scsi | tape device? Have a look at the device/type file in the same path to the filesystem [1] you are taking the MAJOR:MINOR numbers from. If i'm not mistaken, the different options are (taken from the code of vdev [2]):
   0 : DISK
   1 : TAPE
   4 : OPTICAL
   5 : CD
   7 : OPTICAL
0xe : DISK
0xf : OPTICAL
[1] For example, something looking like this:
/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.0/host0/target0:0:0/0:0:0:0/block/sdc/device/type
[2] lines nº1145 - 1168 in vdevd/helpers/LINUX/stat_scsi.c:
https://github.com/jcnelson/vdev/blob/m … tat_scsi.c
#17 2021-05-22 17:16:32
Re: Tape drives
It seems that what is needed is to load the proper driver modules.
ie: modprobe zftape -> depends ftape
This will load zftape and ftape, creating all needed devices under /dev, so there's no MAKEDEV to run.
But this was when you could actually find ftape and zftape for your kernel.
zftape and ftape went awol quite a few years ago, so they were taken out of the kernel from 2.x something on.
I have read in one post that maybe some old Ubuntu may have it, so booting that from a CD may be a solution.
https://retrocomputing.stackexchange.co … with-ftape
Check out these posts:
http://thewunders.org/SxS/storage/ftape.html
https://tldp.org/HOWTO/Ftape-HOWTO-6.html#ss6.1
https://github.com/Godzil/ftape
https://dmitrybrant.com/2020/11/01/how- … -qic-tapes
Good luck ...  8^)
#18 2021-05-23 19:39:39
alphalpha
Re: Tape drives
okay, mt definetly recognized this variable
sorry i cant find anything usefull in /sys/devices/pci0000:00/ , that directory has way to much stuff inside that i never worked with and i dont understand
that might be it
sadly ftape and zftape are not in the kernel anymore
i just downloaded linux-2.1.131
linux-2.1.131.tar.xz                               03-Dec-1998 01:55      8M
ah 1998, the year i got my first computer big_smile
i never tried building anything that old, will try it during the next week
if anyone knows where i can find an old ubuntu or debian iso from that time, please let me know
of course that eliminates any practical usecase for that tape drive, but i am still curious what might be sitting on that tape
thanks very much to everyone who participaded in this thread
you posted a lot of good recources
edit: at some point i may just try to just put it back into that old 486 where i ripped it out and access it from there
but we dont have that monochrome monitor anymore, would it work with any starndard old crt?
#19 2021-05-23 21:11:33
Re: Tape drives
alphalpha wrote:
that might be it
Indeed ...
The problem was that this hardware (my opinion) was not really something solid like all the SCSI tape drives out there at the time.
The advantage was that it was much less expensive to get a QIC/Travan etc. and run it from a parallel port or IDE adaptor card.
But for most, not the real thing.
In my day, I had a QIC and a Travan under Windows but found them to be slow and unreliable.
Here's a link to old Ubuntu releases:
http://old-releases.ubuntu.com/releases/
Try Ubuntu 5.10 (Breezy Badger) or Ubuntu 6.06.2 LTS (Dapper Drake), both have 64bit DVD Live editions:
http://old-releases.ubuntu.com/releases … -amd64.iso
alphalpha wrote:
... any practical usecase for that tape drive ...
Quite so.
With relatively inexpensive fast HDDs to make a multiple Tb NAS with very little investment, tape ends up being cumbersome.
And no, I will not store anything in any cloud.
A cloud is just water vapour: one moment it's there, the next it's gone.
I had my last DAT DD2 drive sitting atop my box for the longest while and finally decided to move it out of the way last week.
A beautiful Sun Microsystems external box hosting a Seagate Scorpion 8000 which saw very little use.
Maybe the box, PS and SCSI board will be of use for something.
alphalpha wrote:
... still curious what might be sitting on that tape
Ahh ...
So that's it.  8^D !
alphalpha wrote:
... put it back into that old 486 where i ripped it out ...
You'll still need the application used to make the tape or download it raw and pick out the bits.
Once you find out what you can do by booting the Ubuntu DVD, you may want to make a VM see if you can access it from there.
Much better than trying anything with the 486.
Cheers,
#20 2021-05-24 14:15:28
dice
Re: Tape drives
i came across this on the cyberciti website which maybe of some use?
https://www.cyberciti.biz/hardware/unix … -commands/
especially thelsscsi program.
list all SCSI devices (or hosts) currently on system
edited: got the command wrong for lsscsi, i typed lsscpi
