#1 2021-04-01 21:24:22
[SOLVED] Devuan Beowulf not upgrading to 4.19.0-16-amd64
I run a parallel Devuan Beowulf installation in my box, on another separate drive.
Yesterday I updated/upgraded my regular/daily installation, 30+ files which included 4.19.0-16-amd64.
I was wanting to the same with this other installation but it did not list the 4.19.0-16-amd64 upgrade.
apt update && upgrade does not list it.
My /etc/sources/list is this:
## package repositories
# Changed - 20210401 - from Beowulf installation
# beowulf stable
deb http://deb.devuan.org/merged beowulf main contrib non-free
deb http://deb.devuan.org/merged beowulf-security main contrib non-free
deb http://deb.devuan.org/merged beowulf-updates main contrib non-free
# needed x virtualbox backport - enable to update package
# deb http://deb.devuan.org/merged beowulf-backports main contrib non-free
# needed x nvidia non-free drivers installation
# deb http://deb.devuan.org/merged/ beowulf contrib
# deb http://deb.devuan.org/merged/ beowulf non-free
# virtual box repository x installation
# deb http://download.virtualbox.org/virtualbox/debian/ buster non-free contrib
# deb http://deb.devuan.org/merged/ beowulf main
# deb http://deb.devuan.org/merged/ beowulf-security main
# deb http://deb.devuan.org/merged/ beowulf-updates main
# deb http://deb.devuan.org/devuan/ beowulf-proposed main
# deb http://deb.devuan.org/merged/ beowulf non-free contrib main
# deb http://deb.devuan.org/merged/ beowulf-security non-free contrib main
# deb http://deb.devuan.org/merged/ beowulf-updates non-free contrib main
How can I troubleshoot this?
Edit:
root@devuan3:~# aptitude why-not linux-headers-4.19.0-16-amd64
Not currently installed
The candidate version 4.19.181-1 has priority optional
No dependencies require to remove linux-headers-4.19.0-16-amd64
root@devuan3:~#
My main installation does not have this optional priority.
Why is it here?
Thanks in advance,
#2 2021-04-01 21:55:14
Re: [SOLVED] Devuan Beowulf not upgrading to 4.19.0-16-amd64
Is the linux-image-amd64 metapackage installed in both systems?
EDIT: or linux-headers-amd64.
#3 2021-04-01 22:11:44
... linux-image-amd64 metapackage installed ...
Indeed.
That was it.  8^)
Happens when you install from the ground up with a skinny net-install.
Forget lots of things.
Thanks a lot for your input.
