#1 2021-03-30 01:02:20
Spaceman Spiff
Installing nvidia?
Is this correct? Install nvidia detect, run, then install driver. Is it that all or am I missing something?
How to install NVIDIA driver using Debian repository step by step instructions
    Enable the non-free and contrib repository.
    As an administrative user open the /etc/apt/sources.list and add the non-free repository. For example change the repository definition:
    deb http://ftp.au.debian.org/debian/ buster main
    TO:
    deb-src http://ftp.au.debian.org/debian/ buster main non-free contrib
    Once ready update the repository index files using the below command:
    # apt update
    Install nvidia-detect utility by execution of the below command:
    # apt -y install nvidia-detect
    Detect your Nvidia card model and suggested Nvidia driver. To do so execute the above installed nvidia-detect command. For example:
    # nvidia-detect
    Detected NVIDIA GPUs:
    01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] [10de:1c03] (rev a1)
    Checking card:  NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1)
    Your card is supported by the default drivers and legacy driver series 390.
    It is recommended to install the
        nvidia-driver
    package.
    As suggested install the recommended driver by the previous step:
    # apt install nvidia-driver
    All done. Reboot your Debian 10 Buster Linux box:
    # systemctl reboot
#2 2021-03-30 12:39:08
Re: Installing nvidia?
Spaceman Spiff wrote:
Is this correct?
How to install NVIDIA driver ...
I had quite a few issues with the nVidia installation in Beowulf, but then I was installing the legacy340xx version which may or may not had been the cause of my problems.
In any case, have a read here, don't skip anything:
https://dev1galaxy.org/viewtopic.php?id=3820
Dev1 member HevyDevy figured out what was going on and how to do it properly.
By following his instructions I was able to successfully install the 340xx in Beowulf.
Apparently his last post/access was 2020-09-20, if you run into trouble with this maybe he'll chip in.
But the instructions he posted were rock solid.
Cheers,
