#1 2021-03-09 13:56:35
nauved-rex
[SOLVED]LXDE: Privilege Elevation Doesn't Work
A 4 TB HD is plugged into a USB port. When I boot up and log on, it appears in PCManFM. However, when I click on it, I get
Not authorized to perform operation
So then I can mount it manually to a local folder, so no problem. However, it should "hot mount", right?
When I was running ASCII, I had to replace LightDM with LXDM to solve problems like this. Under Beowulf, this doesn't help.
I have chrome-remote-desktop installed on this computer. Could this be interfering? I may try uninstalling it, just to be sure.
#2 2021-03-09 16:55:09
Re: [SOLVED]LXDE: Privilege Elevation Doesn't Work
Is the gvfs-backends package installed?
#3 2021-03-09 21:17:34
nauved-rex
#4 2021-03-11 20:40:43
nauved-rex
I installed Lubuntu, now I don't have this problem.
#5 2021-03-12 01:13:05
I just installed lxde in beowulf to see how it is. Starting with just a standard (no-X) system, apt refused to install the lxde metapackage or any individual parts until I tried intsalling lxde and policykit-1 together. Then it worked.
I did not test removable drives because I'm testing in a qemu VM. But the user could not shutdown or reboot from the desktop without entering the root password and not at all from the lightdm login screen. All the polkit and elogind stuff was there. Turned out that udisks was missing. When I added that, shutdown and reboot were active on desktop and login screen.
#6 2021-03-12 10:15:27
nauved-rex
Interesting
#7 2021-03-12 15:44:46
Here's a live-iso I made today. It's a proof-of-concept, experimental, unofficial, and it looks like it works just fine.
Beowulf, LXDE, it has both lxdm and lightdm with lxdm the active display manager. I forgot to remove lightdm. To change the default, run dpkg-reconfigure lightdm
There's not much more than what comes with lxde. Just a few apps. No gimp or libreoffice.
https://get.refracta.org/files/experime … 2_0818.iso
Login: Password
user:user
root:root
sha256sum:
6d4247852ea41865b0f1977ea88f8399f6ddab4b55c91da079ce1536c443b859  snapshot_beowulf_lxde_amd64-20210312_0818.iso
#8 2021-03-14 00:33:23
nauved-rex
Login: Password
user:user
root:root
sha256sum:
Thanks, Admin! This is rather nice. I booted it up on my Chromebook. I had to edit the boot text to include i915.fastboot=1 because of a somewhat incompatibility which causes a flashing screen, but after this, I came to the desktop.
After inserting a MicroSD card, I was able to browse the media using pcmanfm. So right now, I'm clueless as to why I had a problem earlier. I will try installing from the netinst.iso again soon, and will let you know.
#9 2021-03-14 05:06:48
nauved-rex
Update: I downloaded the netinst.iso and installed the default desktop. (Normally, I roll my own install after booting to a command line.)
So after opening in XFCE, I installed LXDE. Everything works fine except for dynamic brightness control. No problem at all accessing attached storage. For brightness control, I added the following line in .config/lxsession/LXDE/autostart:
xrandr --output eDP-1 --brightness .85
which was a very comfortable level.
After a reboot, the xfce4-power-manager slider easily controlled the brightness.
After uninstalling LibreOffice and several multimedia programs, I was only using 3 GB, which is great!
#10 2021-03-14 17:56:33
nauved-rex
I think the answer lies in the udisks package. When I roll my own, it likely never gets installed. So when I try one more time, I will check for this. The name of the package is udisks2.
