#1 2021-03-03 13:43:47
pootler
Very slow wifi!!
HI,
I have a recent install of devuan.
it was working fine up to about a week ago.
Since then , my wifi speed has dropped to about a tenth available?
Our other house devices all achieve maximum speed via the same wifi
I have completely removed any software installed from the last two weeks ago, just in case, but no luck.
<iwconfig wlan0>      gives me;
IEEE 802.11  ESSID:"xxxxxx"
          Mode:Managed  Frequency:2.432 GHz  Access Point: 94:0B:19:B7:98:C8
          Bit Rate=54 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=59/70  Signal level=-51 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:164  Invalid misc:4054   Missed beacon:0
Anybody any ideas on troubleshooting? - I am a linux noob.
Hardware is  BCM 4322 chip, and rtl 8168 adapter.
I changed from Wicd manager to network manager - but nothing changed.
I vaguely remember  something on install about a rtl8168 firmware not being found, so I have installed the latest ''dkms' for that hardware?
Many thanks in advance.
pootler
#2 2021-03-03 13:49:59
dice
Re: Very slow wifi!!
do you have non-free repositories added to your sources list?
what is the output of this file /etc/apt/sources.list
and is there anything in /etc/apt/sources.list.d/
#3 2021-03-03 14:12:49
pootler
ok here is sources list
deb cdrom:[Devuan GNU/Linux 3.0 (beowulf) amd64 - desktop 20200526]/ beowulf contrib main non-free
# A network mirror was not selected during install.  The following entries
# are provided as examples, but you should amend them as appropriate
# for your mirror of choice.
deb http://deb.devuan.org/merged beowulf          main
deb http://deb.devuan.org/merged beowulf-security main
# beowulf-updates, previously known as 'volatile'
deb http://deb.devuan.org/merged beowulf-updates main
deb http://deb.devuan.org/merged beowulf-backports main
here is sourceslist.d
deb [arch=amd64] https://brave-browser-apt-release.s3.brave.com/ stable main
- so , no , I do not have any non-free repos.
I installed 4322 software via .deb packages.
pootler
#4 2021-03-03 14:23:46
dice
Ok you need to add non-free and contrib repos to make your card work properly.
you need to purge the rtl8168 dkms package first though.
read this ... https://packages.debian.org/buster/r8168-dkms
and then read this ... https://wiki.debian.org/bcm43xx
yours is b43 and b43legacy section so you need contrib and non free added to sources list.
I noticed something odd though, in Tx excessive retries:164  Invalid misc:4054   Missed beacon:0 from iwconfig wlan0.
Invalid misc:4054
that is a huge number and from websearch this might be wifi interference?
Have a read here... https://unix.stackexchange.com/question … -to-fix-it
#5 2021-03-03 15:44:03
pootler
Thanks dice for the help.
Will look into this - but  a bit later
Will update .
pootler
#6 2021-03-04 07:56:30
blackhole
The "invalid misc" is what you need to look into. The other devices may be ok, but is this computer closer to any potential sources of interference?
rtl8168 is your ethernet.
The broadcom devices supported by the b43 driver will not work at all without proprietary firmware extracted from the wl vendor driver tarball. If you installed what was needed  via downloading and installing with dpkg, then you've probably done enough, but it wouldn't hurt to enable contrib and non-free repositories as suggested, and do an upgrade, just in case whatever packages you downloaded were for an older release? Perhaps you can elaborate on why they were installed manually and where they were sourced from?
Or did you in fact instlll wl via some other source?
#7 2021-03-04 11:26:26
pootler
O.K
back.
I have a rule that if it takes me more than a couple of days to troubleshoot, then I fresh install.
My time - and life - is too short :-)
Its what I've always done - even with my windoze and mac installs.
SO---
Fresh install with ethernet cable connected.
I presume it will have updated to latest Beowulf?
Used dpkg in terminal to install b43 fw-cutter , and firmware b43 installer.
All went fine.
Using default  WIcd manager getting stupidly low speeds , and stupidly high ''invalid misc" - even if I park myself  a foot away from the router.
This was receiving full speed  ( 30-35 mb/s)  about two weeks ago??
IEEE 802.11  ESSID:"xxxxxxx"
          Encryption key:off
          Link Quality=60/70  Signal level=-50 dBm
          Tx excessive retries:86  Invalid misc:1196   Missed beacon:0
My troubleshooting as a noob is poor , but the only thing I can think has changed is beowulf itself? - the version
confused
pootler
P>S  OK,  I installed a fresh copy of windows 10, wifi is working great on that, so I don't think its is hardware related.
                 have reinstalled Devuan again - same problem as before.
#8 2021-03-04 12:01:20
dice
I cant see how reinstalling is going to help, as you have noticed you still have the same issue.
what is the output of this command from your terminal?
lspci -knn | grep -A3 "Network"
#9 2021-03-04 12:23:53
dice
depends on the broadcom card i believe. Debian saying BCM4322 (only 14e4:432b);
as for the ethernet, devuan should have pulled in firmware-realtek had non-free been enabled in the sources.list (with an update upgrade) which i believe should cover the firmware for rtl8168 ?
these two packages is what should be installed to make it functional?
https://packages.debian.org/buster/firm … -installer
https://packages.debian.org/buster/firmware-realtek
#10 2021-03-04 13:49:58
pootler
I disagree
A fresh install means we can rule out any 'cxxp' that might be in the system caused by noobs ( ie  me smile ) messing about, not quite knowing what they are doing- just in case it might be the problem
Will post output when I get home
Cheers
Pootler
#11 2021-03-04 14:52:38
dice
I disagree
Cheers
Pootler
I get that but imo you need to learn from mistakes and most issues can be resolved with attention to detail and some research. Reinstalling in your case is seriously not needed, the only time i would reinstall would be when i have deleted by accident a directory or file that is system dependent that i dont have a backup for.
#12 2021-03-04 16:33:33
pootler
O.k this is the output:
03:00.0 Network controller [0280]: Broadcom Limited BCM4322 802.11a/b/g/n Wireless LAN Controller [14e4:432b] (rev 01)
    Subsystem: Hewlett-Packard Company BCM4322 802.11a/b/g/n Wireless LAN Controller [103c:1510]
    Kernel driver in use: b43-pci-bridge
    Kernel modules: ssb
BTW, here is my sources list
deb http://deb.devuan.org/merged beowulf          main contrib  non-free
deb http://deb.devuan.org/merged beowulf-security main contrib non-free
deb     http://deb.devuan.org/merged beowulf-updates main contrib non-free
deb     http://deb.devuan.org/devuan beowulf-proposed-updates main contrib non-free
deb     http://deb.devuan.org/merged beowulf-backports main contrib non-free
cheers
pootler
#13 2021-03-04 16:45:40
I think that card would work better with the wl driver:
# apt install linux-{image,headers}-amd64 broadcom-sta-dkms
# if [ "$?" = 0 ] ; then echo 'It worked!' ; else echo 'Trying again...' ; apt install -f ; dpkg-reconfigure broadcom-sta-dkms ; fi
As an aside I'm not sure you want that "beowulf-proposed-updates" source line, it may cause problems in the future. Unless you want to help find bugs ofc.
#14 2021-03-04 17:03:56
pootler
I'll give it a whirl :-)
cheers
#15 2021-03-04 17:18:03
pootler
Well- would you believe it - it  works?
here is terminal output to confirm change:
    Kernel driver in use: wl
    Kernel modules: ssb, wl
happy - but a bit confused- I have never used this driver ,as all the info suggests my bcm 4322 (14E4:432B)  is provided for by the alternate drivers?
AH well - thanks very much for the suggestion 'head on a stick"
pootler
#16 2021-03-05 07:10:20
dice
Ah i missed wl driver section. Good to know anyhow thanks head on a stick. https://wiki.debian.org/wl#supported
so pootler have the speeds gone back to normal?
#17 2021-03-05 12:52:54
pootler
Yup - back to normal.
Thanks for your help as well dice.
Keep safe everyone.
Pootler
