#1 2021-02-24 10:40:47
mclien
recommented init system
I'm about to install my new machine.
Most things are like I'm used to from debian of course.
But: Is there any init system recommented by devuan?
If, not any other criteria to choose one?
thx mclien
#2 2021-02-24 10:48:23
yeti
Re: recommented init system
Use the default, Luke!
<πš‹πš˜πšπš’ πš˜πš—πš•πš˜πšŠπš='πšπš˜πšŒπšžπš–πšŽπš—πš.πš‹πš˜πšπš’.πš’πš—πš—πšŽπš›π™·πšƒπ™Όπ™»="π™³πš’πšœπšŠπš‹πš•πšŽ π™Ήπš‚!";'>
π”“π”©π”’π”žπ”°π”’ π”©π”’π”žπ”³π”’ 𝔢𝔬𝔲𝔯 π”£π”žπ”²π”©π”±π”° 𝔦𝔫 𝔱π”₯𝔒 𝔰𝔒𝔠𝔱𝔦𝔬𝔫 π”Ÿπ”’π”©π”¬π”΄ π”žπ”«π”‘ 𝔑𝔬𝔫'𝔱 𝔣𝔬𝔯𝔀𝔒𝔱 𝔱𝔬 π”²π”«π”°π”²π”Ÿπ”°π” π”―π”¦π”Ÿπ”’!
#3 2021-02-24 10:56:20
mclien
thx.
Btw: is there a a way to send PM which I' missing?
#4 2021-02-24 11:11:58
yeti
Not every user allows PMs.
Look for the envelope pic and Email link below the user name.
Sometimes it's missing sometimes not...
#5 2021-02-24 12:52:39
Ogis1975
Yes, use default (sysvinit). It is rock solid and easy to use. Another choose (runit and openrc) is for those who know what they are doing.
            ----+- Peter Kropotkin -+----
#6 2021-02-24 14:35:38
dice
as has been said already use sysvinit if you are beginner. I havent tried runit on devuan yet but i have on voidlinux and imo is a really good init there. Im not sure how it works on devuan, but i believe sysvinit is still required to function for runit to work??
#7 2021-02-24 16:16:00
No, the runit-init package can be used for PID1: http://dev1galaxy.org/viewtopic.php?id=3628
It is also possible to use openrc-init instead of sysvinit: http://dev1galaxy.org/viewtopic.php?id=2788
@OP: I wouldn't recommend sysvinit, both runit-init and openrc-init are superior and still under active development (sysvinit is "maintained" by Jesse from DistroWatch but it's dead really). Related: https://busybox.net/~vda/init_vs_runsv.html
Brianna Ghey β€” Rest In Power
#8 2021-02-24 16:39:25
Started off with sysvinit under ASCII some years ago, then experimented with openrc in VBox and finally installed an AMD470/Ryzen 2700X with openrc / ASCII. Motivation: refer to HOAS comment in the previous post.
Meanwhile all my active PCs at home have moved to openrc/Beowulf. With my kind of operation (office and internet, a nfs fileserver in the background) I have no issues found.
Currently I am investigating runit/Chimaera in VBox.
I can only encourage you to try openrc.
