#1 2021-02-21 14:32:26
[SOLVED] Heads up: dpkg error -> caused by added kvm group
While tidying up a parallel Beowulf installation I have on another drive (to eventually migrate to Openbox instead of XFCE) I came across this problem:
It was previously upgraded from ASCII.
root@devuan3:/etc/apt# apt upgrade
Building dependency tree
Calculating upgrade... Done
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up eudev (3.2.9-8~beowulf1) ...
The group `kvm' already exists and is not a system group. Exiting.
dpkg: error processing package eudev (--configure):
 installed eudev package post-installation script subprocess returned error exit status 1
 eudev
Reinstalling eudev brings up this:
root@devuan3:/etc/apt# apt-get reinstall eudev
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
E: Internal Error, No file name for eudev:amd64
Trying to fix brings up this:
root@devuan3:/etc/apt# apt install -f
 eudev
Same with a dist-upgrade:
root@devuan3:/etc/apt# apt-get dist-upgrade
 eudev
I then recalled that (on this installation) at one time last year I had some hassle in dmesg with respect to group kvm:
[   14.484174] udevd[395]: specified group 'kvm' unknown
See https://dev1galaxy.org/viewtopic.php?id=3850
... which I solved by simply creating the %&/$*~ group but in turn originated the eudev problem.
I removed the offending kvm group and all is well:
root@devuan3:~# apt update && apt install -f && apt upgrade
Hit:1 http://deb.devuan.org/merged beowulf InRelease
Hit:2 http://deb.devuan.org/merged beowulf-security InRelease
Hit:3 http://deb.devuan.org/merged beowulf-updates InRelease
All packages are up to date.
root@devuan3:~#
Maybe at the 3.1 point release the kvm issue got fixed and it does not show up in dmesg.
I'll check and add the info later on.
Cheers,
#2 2021-02-21 14:51:01
Re: [SOLVED] Heads up: dpkg error -> caused by added kvm group
It seems that basic common sense prevailed, most probably within the Devuan maintainers/packagers. (Thanks!)
ie: no quemu package installed? Then no kvm device node or group needs to be added to the system.
Elementary ...
groucho@devuan3:~$ sudo dmesg | grep -i eudev
[    1.445705] udevd[94]: starting eudev-3.2.9
[   14.557986] udevd[391]: starting eudev-3.2.9
groucho@devuan3:~$ sudo dmesg | grep kvm
groucho@devuan3:~$ sudo dmesg | grep unknown
groucho@devuan3:~$
Cheers,
#3 2021-02-21 15:10:17
#4 2021-02-21 17:36:38
fsmithred wrote:
Thanks.
You're welcome ...
fsmithred wrote:
They're working on it.
As far as I can understand, it is already fixed.
I had added the kvm group to the system in order to get rid of this complaint in dmesg:
It was caused by a bug in PR 5597 that created a kvm node in Debian independently of quemu being installed.
So a bug was filed.
See https://github.com/systemd/systemd/issues/6360
But an argument in favour of this being a necessary feature and not a bug was put forth by head dick Poettering:
Anyway, I am very sure that /dev/kvm should be considered a standard system concept now, sharedby apps, and generic enough to be set up by systemd properly. I hope this makes some sense, and will close this now...
So I added the (unnecessary) kvm group and the dmesg complaint was no more.
But on a dist-upgrade to my ASCII I got the error in the OP and the error went away after I removed the unnecesary and non-system kvm group.
So, it seems that Devuan 3.1 does not create a kvm node and group by default, independently of quemu (or any other software) being installed.
Which is (if I understood correctly) how the principle of modularization works.
ie: a device node and group are created as needed by the software and not by default on installation of the OS.
Did I get this right?
Thanks in advance,
