#1 2021-01-27 04:55:25
Dutch_Master
Proxmox on Devuan
Proxmox is build on Debian, so in theory at least, Devuan should be a suitable replacement. Anyone tried that yet?
Proxmox has a page outlining how to install it on an existing Debian install (click!) so it shouldn't be too difficult.
Is there any reason it wouldn't work?
TIA!
#2 2021-01-27 05:50:53
szutt
Re: Proxmox on Devuan
Proxmox heavily rely on systemd now https://forum.proxmox.com/threads/build … uan.61289/
#3 2021-01-27 06:31:46
Proxmox is also fundamentally broken if the _many_ support threads we get over at fdn are anything to go by. The fuckers even refer users to our forum in case of problems mad
#4 2021-01-27 07:02:21
I would  ditch that software in a heartbeat. If it requires systemd as much as it does, then it must be crap.
That being said, I am not entirely sure what its for.
Or if there are alternatives to it. I may look later...
hmm, dunno which ones use systemd though...
But i found one named danube cloud... You tell me if its any good. tongue
Yeah, there sure don't look like there are a lot... hmm
#5 2021-01-27 13:10:47
Dutch_Master
Hmmmm..... Right, let's not go that way then.
OK, so, what next? I've never seen a live Proxmox install so I have no idea how that works. But I did find that it uses qemu and lxc for the virtualization, so at least in theory one could write a script to implement the functionality, if not the web-gui. Btw, as Proxmox is OSS, one could rewrite all the systemd-specific parts for other init systems, but as a non-coder, that's not gonna be me! Personally, I'd like a choice of underlying file systems, like BTRFS, JFS and XFS instead of "just" ZFS but I can imagine this to seriously complicate porting functionality now offered by ZFS over specifically JFS and XFS (BTRFS has a similar feature set to ZFS)
Time to ponder off and do some experimenting, I guess. Just don't hold your breath for it, it'll be a while (if ever!) tongue
#6 2026-10-21 10:31:02
saki
Proxmox on Devuan is possible. POC can be found at https://github.com/psakar/proxmox-devuan
I'm running it on my homelab,
Beware - it was built with help of Claude. No ZFS or Ceph ATM
