#1 2021-01-12 12:17:12
zerrax
[SOLVED] Devuan XFCE autologin
I am trying to get auto login to work in Devuan Buster with XFCE
I tried a lot of solutions on the internet without success...
username: john
My current /etc/lightdm/lightdm.conf looks like this:
[Seat:*]
autologin-user=john
autologin-user-timeout=0
and I did this:
groupadd -r autologin
gpasswd -a john autologin
still no success, can anybody help me?
#2 2021-01-12 20:48:47
Re: [SOLVED] Devuan XFCE autologin
Perhaps it should say [SeatDefaults] rather than [Seat:*] ?
#3 2021-01-13 14:14:45
zerrax
Tried it, but no still I get the "red" loggon screen of Devuan XFCE.....
#4 2021-01-13 18:22:08
Check the logs.
#5 2021-01-13 21:36:24
Btw, are you sure you are using lightdm and not slim which is the default in Devuan ?
If the latter, you'll rather need to edit /etc/slim.conf to have default_user and auto_login set up.
#6 2021-01-14 14:41:53
zerrax
Thank you for your response, the above solved the problem, and autologin works now!
I didn't know that Devuan used slim instead of lightdm :-)
