#1 2020-12-11 07:23:35
darry1966
Iwl4965 and HPdv6000
The module for my wireless card IWL4965 does not load consistently in Devuan Beowulf is there a fix???
#2 2020-12-11 09:46:41
PedroReina
Re: Iwl4965 and HPdv6000
Could you support this with some log messages? Or describing the inconsistent behaviour?
#3 2020-12-11 17:38:39
darry1966
Hi Pedro,
the behaviour this - the machine loads to desktop and no connections with wicd show.  The firmware for iw4965 is not loading every boot.  Have to reboot to get it to - then I can connect.  Is there an answer to this problem??
#4 2020-12-11 18:09:00
Try grep iwlwifi /var/log/syslog and see if there are any error messages.
And please do the following for me. lsmod | wc -l and compare the numbers you get when the wireless does and does not connect after a reboot. Let me know if they are different. Thanks. You could also do lsmod |grep iwlwifi to see if the wireless module is loaded.
#5 2020-12-11 19:39:46
I think the card uses the legacy driver so
grep iwl4965 /proc/modules
And if it isn't loaded use
# modprobe iwl4965
If that fixes things then add the module name to /etc/modules (or to a file under /etc/modules-load.d/) to force load it every boot.
#6 2020-12-11 20:57:31
Maybe. I just did 'apt-cache search IWL4965' and it showed firmware-iwlwifi.
grep for just 'iwl' and they can all show up.
I'd like to rule out eudev as the source of the problem before anything else is changed. If so, there's a fix in beowulf-proposed-updates. https://bugs.devuan.org/cgi/bugreport.cgi?bug=483
#7 2020-12-12 05:29:02
darry1966
Thanks guys I will try these ideas out.  The problem is very random.  Thanks all.
#8 2020-12-13 11:25:55
PedroReina
In my experience, random behaviour is very often caused by faulty hardware.
#9 2020-12-14 19:22:12
^ +1
#10 2020-12-14 23:19:10
F_Sauce
https://wiki.debian.org/iwlegacy
I believe Head_on_a_Stick and fsmithred might be on the track.
Cheers,
Olav
I'm on Devuan with KDE
