#1 2020-12-01 21:54:08
Beowulf kernel question
Today I put a spare HDD on my 1000HE to try and see how devuan_beowulf_3.0.0_i386 does there, hardware limitations and all.
Downloaded the netinstall *.iso here: https://files.devuan.org/devuan_beowulf/installer-iso/
groucho@eee-dev3:~$ uname -a
Linux eee-dev3 4.19.0-12-686 #1 SMP Debian 4.19.152-1 (2020-10-18) i686 GNU/Linux
groucho@eee-dev3:~$
A line in dmesg caught my attention:
[    0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
But the Intel Atom N280 inside is PAE able.
groucho@eee-dev3:~$ cat /proc/cpuinfo | grep flags | grep pae
flags		: fpu vme de pse tsc msr *pae* mce cx8 apic sep mtrr pge mca cmov pat clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx constant_tsc arch_perfmon pebs bts cpuid aperfmperf pni dtes64 monitor ds_cpl est tm2 ssse3 xtpr pdcm movbe lahf_lm dtherm
groucho@eee-dev3:~$
It seems I may have installed the wrong kernel?
Can this get fixed without reinstalling?
TIA,
#2 2020-12-01 23:22:21
Re: Beowulf kernel question
Install linux-image-686-pae if you want the metapackage (so you get updated kernels with your regular package upgrades). Or else you could install linux-image-<version>-686-pae for a specific kernel.
#3 2020-12-01 23:45:30
Thanks for the fast reply.  8^)
fsmithred wrote:
Install linux-image-686-pae if you want the metapackage ...
Or else you could install linux-image-<version>-686-pae ...
I was fiddling with the install and ended up installing both.
Seems the metapackage is the best/most convenient option.
Should I uninstall the version specific package?
It's taking up space.
TIA,
#4 2020-12-02 01:33:50
if you use the meta (package) you'll need the version specific (package) too.
#5 2020-12-02 04:18:20
You can uninstall the non-pae kernel after you reboot into the new one.
#6 2020-12-02 10:13:58
Right ...
Done.
Now NX protection is active.
Thank you both for your input. 8^D
