#1 2020-12-01 06:44:25
dataslanger
Devuan mounting remote NFS shares in /etc/fstab BEFORE network is up?
I am running Devuan ASCII, so I am not sure if this is applicable to Beowulf, however I have several local-network NFS mounts in /etc/fstab. While booting, Devuan launches rpcbind and other NFS-related daemons and then apparently tries to mount these filesystems unsucessfully and causing the boot to hang for several minutes, as it would seem the interface configuration from /etc/network/interfaces has not yet come up.
Anyone know why this is? I am unable to pull up the messages and errors because they were displayed during the init run-up at boot, and are apparently no where to be found in /var/log.
Thanks
#2 2020-12-01 16:20:08
Re: Devuan mounting remote NFS shares in /etc/fstab BEFORE network is up?
You should probably post /etc/fstab and /etc/network/interfaces.
I don't use NFS myself but I would check https://wiki.archlinux.org/index.php/NF … /etc/fstab — the _netdev option looks relevant for this problem.
#3 2020-12-01 21:23:20
An alternative to solving the problem would be to set up autofs for the nfs mounts. Then they'll mount automatically when you use them.
