#1 2020-11-20 10:58:43
bobemoe
Getting varnish to work on beowulf
Just upgraded from ascii to beowulf and varnish fails to start with:
Error: Could not get socket 0.0.0.0:6081: Address already in use
The solution is to remove the config check from the init.d script as documented here:
https://github.com/varnishcache/pkg-var … /issues/75
Does this need to be added to devuan's init.d scripts somehow so its included automatically?
Big thanks to everyone big_smile
#2 2020-11-20 18:26:22
Re: Getting varnish to work on beowulf
The varnish package is drawn from Debian's repositories so it may be best to reproduce this bug in a Debian system and open a bug report against their package with the patch attached. Just don't mention Devuan in the bug report, some of the Debian developers are funny about that.
Black Lives Matter
