#1 2020-11-09 13:16:30
Magnus
Run Gnome on Wayland with Nvidia drivers on Ceres
Install libnvidia-egl-wayland1
Kernel parameters nvidia-drm.modeset=1
Comment out the line with "DRIVER==nvidia" in /lib/udev/rules.d/61-gdm.rules
Comment out the line with "WaylandEnable=false" in /etc/gdm3/daemon.conf
Restart
Write echo $XDG_SESSION_TYPE in a terminal to see if you run x11 or Wayland
#2 2020-11-11 17:05:01
swarfendor437
Re: Run Gnome on Wayland with Nvidia drivers on Ceres
Personally I can't stand Wayland. I am much happier with X running Nouveau drivers - can appreciate it if someone is in to gaming, but I reserve that for the PS4 Pro.
#3 2020-11-11 17:16:31
Wayland is very infected with redhat's nonsense... ;(
So yeah, Xorg is the only option I see sadly...
#4 2020-11-12 13:29:34
Magnus
Wayland and Gnome is the only combination (must tell I didn't know how it is on KDE) there you get a completely color managed environment. Even the desktop picture is color managed. Because I use Linux even to photomanagement It's a big step forward. And Wayland works fine.
#5 2020-11-12 18:10:41
The colord backend works for pretty much any desktop and can even be used from the command line:
https://www.freedesktop.org/software/colord/using.html
I'm a Wayland fan myself though so thanks for this guide, I had no idea it could be made to work with NVIDIA hardware. Not that I would buy anything from those bastards big_smile
#6 2020-11-13 00:58:54
Well whatever works for you. :0
#7 2020-11-13 07:23:03
Magnus
Yes, color management work in those applications that has built support för color management. But in Gnome on Wayland color management works for the hole environment: The desktop picture, the window frames, themes and everything.
#8 2020-11-13 07:24:47
Magnus
zapper wrote:
Well whatever works for you. :0b
Thank you very much for that freedom. You are so kind. ;-)
#9 2020-11-13 10:40:29
Heh, your sarcasm amuses me. wink
#10 2020-11-24 22:27:40
Magnus
Now discovered that I could not start Gnome boxes in Wayland. Searched a bit and found that I needed egl-wayland (libnvidia-egl-wayland1) version 1.1.5 + a patch.
Found an Arch package 1.1.5 including the patch at https://ftp5.gwdg.de/pub/linux/archlinu … kg.tar.zst
Unpacked the package and manually replaced two Devuan Ceres version 1.1.4 files at "/usr/lib/x86_64-linux-gnu/" with the package "/usr/lib/libnvidia-egl-wayland.so.1" and "/usr/lib/libnvidia-egl-wayland.so.1.1.5". Also chmod and chown the new files to have the same as the replaced files.
Restarted. Launched Gnome boxes.
