#1 2020-10-27 22:31:19
nobodyuknow
SOLVED: Sound app non-operational and PulseAudio not running
I tried to play some music on a recently built Beowulf Cinnamon system. No sound came from the headphones. The Sound application is broken, with Volume slider completely non-responsive, though I can move Balance, Fade, and Subwoofer sliders. The Test Sound button in the Sound app is also broken.
I checked PulseAudio:
pacmd list-sinks
No PulseAudio daemon running, or not running as session daemon.
I went to Startup Applications and saw that PulseAudio is set to start.
I have no trouble playing music on Linux Mint using the same hardware.
From looking at posts here, this appears to be a common issue.
#2 2020-10-28 06:42:39
larsH
Re: SOLVED: Sound app non-operational and PulseAudio not running
Hi
Look at the release notes on how to enable pulseaudio
Have a nice day
Lars H
#3 2020-10-28 19:10:45
nobodyuknow
The file in question specifically states "# If you are not using systemd, comment out this line." Since Devuan is, by definition, systemd-free, shouldn't the line in question be commented-out in the ISO?
Okay, I've learned my lesson. From now on, before installing Devuan, I will read the release notes.
Thanks for the reply.
#4 2020-10-28 19:20:58
larsH
Hi
You are most welcome. You are absolutely not the only one. This question pops up at least once per week.
Have a nice day
