#1 2020-09-29 20:53:11
bbatten
arptables
I am using iptables-legacy. From the installation procedure output:
iptables (1.8.1-1) unstable; urgency=medium
    By default, this package will try to use the nf_tables kernel backend
    instead of the xtables one. Please, read more about this in
    /usr/share/doc/iptables/README.Debian, including details about the new
    update-alternatives configuration possibilities.
    This is a major update on the way iptables works and may have severe impact
    in running systems which are upgrading between Debian versions.
    The arptables and ebtables binaries are also affected, and those packages
    will be updated soon as well.
-- Arturo Borrero Gonzalez <arturo@debian.org>  Wed,  24 Oct 2018 14:00:00 +0200
Bottom line is I'm screwed. My iptables setup no longer works.
Is it safe to use the Debian arptables and ebtables packages? the README.debian says arptables-legacy and ebtables-legacy are in the Debian packages.
Thanks,
#2 2020-09-30 16:38:45
Re: arptables
Have you tried
# apt install {eb,arp}tables
# update-alternatives --set arptables /usr/sbin/arptables-legacy
# update-alternatives --set ebtables /usr/sbin/ebtables-legacy
#3 2020-09-30 21:20:03
Re: arptables
You might also want to reinstall iptables without nftables; perhaps something like
# apt-get install --reinstall nftables- iptables
That should give you a set up that allows the "normal" iptables rules.
#4 2020-10-01 06:09:52
Re: arptables
^ Looks like the OP is already using the legacy iptables version.
And anyway there's no need to uninstall nftables:
# update-alternatives --set iptables /usr/sbin/iptables-legacy
#5 2020-10-01 10:38:43
xinomilo
Unknown
Re: arptables
#6 2020-10-04 21:31:57
bbatten
Re: arptables
Thanks for the replies.
@ralph.ronnquist: I don't have nftables installed.
@Head_on_a_Stick: I installed ebtables and arptables, then updated etc-alternatives per your suggestion. No luck.
FWIW, while running on ascii, I did not have ebtables or arptables installed. Things worked just fine without them. I suspect that iptables-legacy for beowulf is not really bit-for-bit the same as the iptables available in ascii. Is there an "oldstable" for devuan that would allow me to purge beowulf iptables, arptables, and ebtables, then install the version of iptables available there?
Thanks,
#7 2020-10-04 22:33:00
Re: arptables
I've tried this, it's hectic! but only because I was trying to stick with iptables instead of ebtables, I don't know why really,
I just didn't want to change from iptables squid firewalled proxy server setup I'd been using for years.
I ended up changing my scripts to nftables, seems to work ok.
I used arch and gentoo help/wiki pages to work my way through the install and setup.
#8 2020-10-05 01:49:26
Re: arptables
@bbatten: iptables on beowulf (or buster, really) doesn't require arptables or ebtables, but it recommends nftables.
Upon installation, it gets set up to use the iptables-nft alternative implementation and then it provides syntax transparency via /usr/sbin/xtables-nft-multi so as to use the "traditional" iptables rules language for manipulating and reviewing the rules.
It also gives you the option to change it to use the iptables-legacy implementation through update-alternatives.
Doesn't that work for you?
#9 2020-10-06 18:56:06
Re: arptables
bbatten wrote:
No luck.
That is not enough information for us to be able to help you — please post the relevant log entries that show the failures to which you allude.
Can we also see
update-alternatives --display iptables
iptables-save
