#1 2020-09-29 18:01:32
uther
[SOLVED] Cannot run Synaptic & mount drives after update (Beowulf)
After recent update I cannot run Synaptic (launcher and whisker menu) and open encrypted drives (thunar) anymore.
Im running Beowulf Xfce flavour. I can run Synaptic with sudo, and open crypts manually with cryptsetup luksOpen.
When opening encrypted drive I'm getting:
 failed to mount "_my-drive-here_ Encrypted" Not authorized to perform operation.
Appreciate any help.
#2 2020-09-29 18:06:21
Re: [SOLVED] Cannot run Synaptic & mount drives after update (Beowulf)
Do you have any polkit authentication agents running?
pgrep -a polkit
EDIT: if this happened after an update then we should probably also see your sources:
apt policy
Black Lives Matter
#3 2020-09-29 18:14:47
uther
I have policykit
~$ pgrep -a polkit
5210 /usr/lib/policykit-1/polkitd --no-debug
and no pinned packages:
~$ apt policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 100 http://deb.devuan.org/merged beowulf-backports/contrib i386 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=contrib,b=i386
     origin deb.devuan.org
 100 http://deb.devuan.org/merged beowulf-backports/contrib amd64 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=contrib,b=amd64
 100 http://deb.devuan.org/merged beowulf-backports/non-free i386 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=non-free,b=i386
 100 http://deb.devuan.org/merged beowulf-backports/non-free amd64 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=non-free,b=amd64
 100 http://deb.devuan.org/merged beowulf-backports/main i386 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=main,b=i386
 100 http://deb.devuan.org/merged beowulf-backports/main amd64 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=main,b=amd64
 500 http://deb.devuan.org/merged beowulf-updates/non-free i386 Packages
     release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=non-free,b=i386
 500 http://deb.devuan.org/merged beowulf-updates/non-free amd64 Packages
     release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=non-free,b=amd64
 500 http://deb.devuan.org/merged beowulf-updates/main i386 Packages
     release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=main,b=i386
 500 http://deb.devuan.org/merged beowulf-updates/main amd64 Packages
     release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=main,b=amd64
 500 http://deb.devuan.org/merged beowulf-security/non-free i386 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=non-free,b=i386
 500 http://deb.devuan.org/merged beowulf-security/non-free amd64 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=non-free,b=amd64
 500 http://deb.devuan.org/merged beowulf-security/main i386 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=main,b=i386
 500 http://deb.devuan.org/merged beowulf-security/main amd64 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=main,b=amd64
 500 http://deb.devuan.org/merged beowulf/contrib i386 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=contrib,b=i386
 500 http://deb.devuan.org/merged beowulf/contrib amd64 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=contrib,b=amd64
 500 http://deb.devuan.org/merged beowulf/non-free i386 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=non-free,b=i386
 500 http://deb.devuan.org/merged beowulf/non-free amd64 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=non-free,b=amd64
 500 http://deb.devuan.org/merged beowulf/main i386 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=main,b=i386
 500 http://deb.devuan.org/merged beowulf/main amd64 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=main,b=amd64
Pinned packages:
#4 2020-09-29 18:24:40
uther wrote:
I have policykit
~$ pgrep -a polkit
But you don't have a graphical authentication agent running so Synaptic can't ask for a password if you launch it from the menu.
Try this (run the first command as root and the second as your normal user):
# apt install policykit-1-gnome
/usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1 &
Does Synaptic launch from the menu now?
What have you installed from backports?
aptitude search '?narrow(?installed, ?archive(stable-backports))'
Black Lives Matter
#5 2020-09-29 18:39:37
uther
I already have policykit-1-gnome installed.
/usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1 & have resolved the issue. Thanks.
From backports I have installed only newest kernels 5.4 and 5.6.
#6 2020-09-29 18:48:31
That only starts the agent once.
If the package is installed then Xfce should autostart it via /etc/xdg/autostart/polkit-gnome-authentication-agent-1.desktop so check for ~/.config/autostart/polkit-gnome-authentication-agent-1.desktop — that might be overriding it.
EDIT: and your kernels are outdated, you should install the metapackge:
# apt install linux-image-amd64/beowulf-backports
Black Lives Matter
#7 2020-09-29 19:00:08
uther
/etc/xdg/autostart/polkit-gnome-authentication-agent-1.desktop is in place and contains:
Exec=/usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
There's no autostart/polkit-gnome-authentication-agent-1.desktop in ~/.config/autostart
ED: I've updated the kernel and now everything seems to be ok.
